French Drain Help Please - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 09:25 AM   #16
concretemasonry - when you say the holes are on the lower portion if I have a 30 foot retaining wall that I am going to be putting a french drain in. Would I have a 30 foot long pipe with only holes in the last four to eight feet? Is that what you mean by "The holes are on the lower portion (4:00 and 8:00)"?
bsmith95610 is offline   Reply With Quote
Old 02-15-2011, 09:53 AM   #17
Rewards Points: 121
No, he means use a rigid PVC pipe made for this purpose. It has holes the entire length, on the bottom sides. This makes the water drain better and has no ridges like the flexible black stuff. The added bonus is you can snake it out if needed.
JoeLena is offline   Reply With Quote
Old 02-16-2011, 07:22 AM   #18
Rewards Points: 1,548
When installing the pipe you turn it so holes are more or less facing down. The holes don't have to be exactly on the bottom (6 o'clock positon).
If the holes are higher up then the pipe will not collect water until the water level rises higher, to overflow from the surrounding saturated soild into the otherwise empty pipe.
Old 02-16-2011, 08:24 AM   #19
Steeler99's Avatar
right allan, water isn't going to flow directly down and magically all go to the holes if they were on the top. If they were on the top, water would have to fill around and above the drain to seep in.
The main thing is to have the bottom of the pipe be below the bottom of the footing to ensure that the water table doesn't rise to the bottom of the footing
Steeler99 is offline   Reply With Quote
Old 02-16-2011, 11:09 AM   #20
Concrete & Masonry
Rewards Points: 636
Is this french drain actually going at the base of the footing, or just below grade a few feet?
Just for the record, we often put an inch or two of stone under any draintile that lays on already saturated soils. It merely keeps any "soupy" mud out of the pope during const. and backfill. Any stone/gravel material that will allow water to perculate through it will also allow water to perc. out of it. Meaning I've witnessed many applications where the water will drain out of the stone rather than the pipe itself, merely because of gravity.
jomama45 is offline   Reply With Quote
French Drain to Drain Roof DIYTKINNEY Landscaping & Lawn Care 2 11-08-2010 04:53 PM
What's Needed for Drain Tile / French Drain samsmith Building & Construction 2 08-24-2010 11:20 AM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
