Foundation Grade - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 08:05 AM   #1
Rewards Points: 326
Foundation Grade
Hi All,
I need to improve the grade around my house. I might have a challenge in my backyard with my newly installed interlocking stones, but definitely the front and one side of my house have poor grades.
The side is extremely flat and is currently covered with crushed stones. My question is, could I just used more crushed stone to create the slope along the side.
i want my slope going out about 4 ft away, so i need roughly 4 inches high on the wall. I dont mind doing the labour, but just wanted to know the best material to whisk away the water or rain from the foundation.
Thoughts?
for the front of the house, i am replacing the existing entrance and will be improving the grade myself with gravel a and limestone and the fix the sunken spots on my lawn with soil.
Amitabh is offline   Reply With Quote
Old 04-11-2014, 08:23 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
You can not use stone to solve the problem. You will have to remove the stone and slope the dirt away from the foundation and then put the stone back if that is what you want there.
Be care full not to slope the water on to your neighbors property because you might be responsible for any problems it causes.
Robpo is offline   Reply With Quote
Old 04-11-2014, 09:45 AM   #3
Rewards Points: 326
thanx - what do i put (what material) to improve/make the slope? and the slope alone would draw water away? i would figure that the material would continue to absorb it downwards.
Old 04-11-2014, 10:43 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,708
Ayuh,.... High clay content sub-soils will shed water, rather than letin' it soak through like stone,...
Bondo is online now   Reply With Quote
Old 04-11-2014, 12:52 PM   #5
Rewards Points: 326
available at HD or Lowes - or do i need to go to a speciality store. i have been doing some reading...
some claim that sandy soil is better because it compacts better.
Old 04-11-2014, 01:28 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
Sand without the clay will not stop the water from going through it. I don't know where to get clay. What is wrong with the soil there now? You could use almost any compactable, soil/fill dirt.
Old 04-11-2014, 01:42 PM   #7
Rewards Points: 326
nothing is wrong with the current state, its just that its flat. so i need to build a slope.
Old 04-11-2014, 01:59 PM   #8
Rob
Robpo's Avatar
Rewards Points: 826
I mean type of soil. Couldn't you take it from 4' away and move it closer to foundation. The red line is how it is now the brown is after you moved it.
Old 04-11-2014, 02:09 PM   #9
Rewards Points: 326
ah.... mmm... i gotta put my rocks somewhere
Old 04-11-2014, 02:20 PM   #10
Rob
Robpo's Avatar
Rewards Points: 826
Be careful not to slope the water onto your neighbors property because you might be responsible for any problems it causes.
Advice on how to grade foundation oldhouseguy Landscaping & Lawn Care 4 05-01-2013 05:46 AM
Foundation For a Semi-Recessed Storage Shed Under Deck Ranman333 Concrete, Stone & Masonry 10 04-02-2013 08:25 PM
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 12:46 PM
Area between foundation & driveway is below grade - how to raise jefferyscott Landscaping & Lawn Care 4 08-24-2011 06:14 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
