Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-18-2013, 12:24 PM   #1
JOATMON
ddawg16's Avatar
Found Another Use for a Sawzall
"What" you ask does a sawzall have to do with lawn care? Well....besides using it to cut PVC pipe for sprinklers....it does a great job of cutting sod.
The county recently repaired the sidewalk in front of our house and I took advantage of the excavation to put in a pipe so I could have sprinklers in the space between the street and sidewalk (prior to that, it had to be done by hand). Additionally, the grass that was there was done 11 years ago by seed....basically, it looked like crap...not to mention the uneven ground from when a tree was removed 2 years ago.
So...after the sidewalk work was done, I removed all the existing grass and graded the area....I even straightened up the wells for the water and gas valves (my OCD was kicking in).
And as well all know, the dimensions of a space are never in equal increments to match the dim of sod....I ended up with about a 4" bare strip down the side...so...I put a long wood blade on my cordless sawzall...and cut away...quick and easy.
And since it was such a gorgeous weekend....(with rain on the way), we figured it was a good time to get some other yard work done. While the wife did her thing...I rerouted a copper pipe. The hose big for the front hose is not at the house....I put in a T and ran copper pipe to a spot sort of in the middle of the yard. (protected by plants) It works out great. Since we are lowering the flowerbed by about 6", I had to move the pipe...so I made sure that it will never be in the way...it's now real deep and next to the house foundation before it makes the turn to the yard.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 02-18-2013, 06:30 PM   #2
I hope you put a backflow preventer on your water outlet in the yard, to keep dirt, etc. from getting in. That said, nicely done.
GarrettFiveZero is offline   Reply With Quote
Our 1st home, found a buried natural gas line Turbogus Plumbing 7 09-25-2012 06:26 PM
Odd old filter found in wall of Cape from 1940 CoconutPete HVAC 9 06-26-2012 08:55 AM
Hello, thanks. found my mistake MrVivekB Introductions 3 05-26-2012 10:41 AM
Small white sacks found on wood beams tcook555 Pest Control 6 04-17-2012 01:11 PM
Painting Stair Railings - Sawzall!?!? JackOfAllTrades Painting 15 01-04-2010 02:40 AM
