Forms For Quickcrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 04:31 PM   #1
Question
forms for quickcrete
I have made a sidewalk, and patio out of quickcrete and the forms that I bought several years ago... I live in an area that the ground does freeze, and we have plenty of rain in the spring, and fall... I need to know what to add to the grout/mortar in the sidewalk so when it freezes the walk wont be ruined. I can not put just sand in the joints, it will wash away.... ANY SUGGESTIONS would be welcome. the name of the forms that I used is walkmaker.
Last edited by WvRN10; 05-17-2011 at 05:09 PM. Reason: added name of the path mold.
WvRN10 is offline   Reply With Quote
Old 05-19-2011, 09:44 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
The concrete and mortar dont freeze. The water will get underneath it and freeze and push the earth up.
Millertyme is offline   Reply With Quote
Old 05-20-2011, 03:08 AM   #3
Too Short? Cut it Again!
From what I remember, the walkmaker concrete forms only allow for pouring a two inch thickness within the form? What is under what you poured and finished? If your walk is just floating on dirt, and you did not lay down gravel or sand as a base? Every time your soil heaves or even hiccups, you cannot fix it.
Not a solution to your problem but why would sand wash away? And would not any substructure of gravel, sand compacted dirt do the same if you are not retaining at least the bleeding edge?
Reusing concrete forms in home building dalepres Building & Construction 9 04-03-2011 11:31 AM
concrete forms for concrete stairs Brubaker 22 Building & Construction 2 10-12-2010 10:37 PM
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 10:24 AM
tips and tricks for laying and removing concrete forms? Allthunbs Building & Construction 8 06-10-2009 10:20 AM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-23-2008 12:22 AM
