Forming Holes In Surface Of Wet Concrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-25-2008, 10:43 AM   #1
Rewards Points: 20
forming holes in surface of wet concrete
I want to set a few decorative 4" slate tiles in a small concrete slab under an outdoor stair. The tiles will not be ready for weeks, and I'd like to pour the pad this weekend, so my plan was to cut some 4.25" squares from 1/4" plywood, and press these into the wet mix flush with the surface. After it cures, I'll glue some little handles on the back with 15 minute epoxy and pull them out, leaving cavities to glue/grout the tiles into later.
Is this a mistake? Will the wood tend to float out of the wet mix, or other basic problems? Any better ideas for how to do this?
I planned to cut the edges with a 10 bevel to let them release. Is that enough? How tightly will the concrete adhere to the wood, particularly the porous edge grain? I thought I might cork on a bit of paraffin. Would some other release agent be better? Will residue interfere with the later adhesion of the tiles?
Finally, how long should the concrete cure before pulling the plugs? This is in Seattle, so average temp will be 50, roughly.
Thanks,
Mike
mx13 is offline   Reply With Quote
Old 04-25-2008, 05:06 PM   #2
Learning by Doing
Leah Frances's Avatar
Do you have a reason for not laying your slate tiles like this: http://http://www.youtube.com/watch?v=RiWO0nR9B90
Gotta love that Gershwin.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
forming shallow holes in surface of wet concrete mx13 Building & Construction 1 04-25-2008 09:59 PM
correcting slightly uneven small concrete surface amakarevic Building & Construction 5 01-16-2008 07:38 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Removing concrete forming? MLO Building & Construction 3 10-01-2006 10:30 AM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
