Flymo Weedeater Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 06:50 AM   #1
Flymo weedeater problem
Good day
I have a flymo weedeater which I use to neatly trip the edges of my garden. This unique part of equipment is however making life difficult for me.
When using it to trim the edges, it will start making a horrible noise and then both the strings at the bottom will be out - much longer than required.
It then have to stop and turn the weedeater upside down, rotate the string back ont the spool and trim the edges for another 30 seconds before it starts unravelling again.
Please help before I post this weedeater to the dump.
What am I doing wrong.
PS. The string is correct according to the specifications and I have bought a new spool to wind the string onto.
Thank you in advance.
GideonEL is offline   Reply With Quote
Old 01-21-2012, 09:48 PM   #2
Flymo weed eater problem
Hi Gideon, I know how you feel, it's a real pain, after spending a lot of time trying to fix a design fault i found the only answer is to take the spool cover off and remove the cord spool and leave it out.
Next get some heavy grade .080 in.dia. trimmer line. and cut it about 400mm long.
Make a knot 150mm from one end.
Make a knot 150mm from the other end.
You now have a gap of about 100mm between the knots.
working from inside the spool housing, push one end of the line through the double metal posts where the line normally goes out until one knot will stop it, then do the same with the other end of the line then replace the cover.
Then cut each line end to the correct length and your done.
I made two which meant I had double lines coming from each side.
I realize when they wear down you have to replace them but if you make up several spares it only takes a minute or so, and it's really great to be able to work without all the problems...Good luck Bob
jarob is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
