Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-08-2008, 09:48 AM   #16
Long-Time DIYer
Mike Swearingen's Avatar
Floating Barrel Dock
Properly treated pressure-treated wood has a limited warranty of 50 years, and is what we use here in the water in northeastern NC.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-08-2008, 10:41 AM   #17
Custom Cabinet Maker
Agree Mike PT with a minimum level of .40, they do make a higher grade for docks which I think is closer to .06 or so
skymaster is offline   Reply With Quote
Old 02-08-2008, 03:46 PM   #18
I was hoping for some pictures of creations on how to actually join the wood-to-plastic barrel containers..
Dyn'R is offline   Reply With Quote
Old 02-21-2008, 11:10 AM   #19
not sure where you're looking for pressure treated, but there's a nice trick for buying deeply discounted lumber. --Jan-March check any of the northern home improvement stores that have stored their lumber indoors --the winter heat warps anything that wasn't stacked and banded. they'll sell it usually for 10cents on the dollar.
buy it as soon as they start clearing it out, --anything that's not twisted [can easily straighten warp, but can't do much with twist]. stack it onsite on level pallets, --uncovered so that it soaks under spring rains. use adjustable straps every 2' along length to pull in the bends, eventually locking each straight section with metal banding.
no guarantee that some won't remember their bends, but I did a deck with this 2yrs ago in Chicago (buying the wood in February, building in June) and it's still true. --trick is that once it's tied into the structure and living outdoor, it stays wet enough to hold its shape.
so about the floating dock? --anyone have photos to post showing underside barrel details. shopping for the prettiest solution.
pascalle is offline   Reply With Quote
Old 02-21-2008, 05:57 PM   #20
Electrical Contractor
I have a floating dock on my pond. The previous owner built it.
Looks like he laid out the barrels, then built a frame with 2x6.
He allowed about 6" of play, then ran a 2x6 between the frame.
He did this for 5 barrels down each side. He then put 5/4 boards on top for the floor. The wood and barrels are not attached to each other.
Next time I get down there I wiil take some pics. Make sure you get it right, and built on land. You will never be able to submerge the barrel and slide it under the floor in the water!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-22-2008, 02:46 PM   #21
Appreciate that Jbfan!
still wonder though,you say the 'wood&barrels' are not attached..i guess the awaited pictures will be worth 2thousands words in this case!
Old 02-22-2008, 11:38 PM   #22
If I could lift off the deck, all my barrels would float away.
The deck sits on top of the barrels
In fact, that is what happens. The floating dock was tied to the fixed doc. Since we are in a drought, the water level dropped, the tied portion of the floating dock stayed tied up, the back side followed the water, and half of the barrels floated away.
I spent 2 hours chasing my barrels around the pond.
Old 02-23-2008, 06:44 PM   #23
JbfanWrote:"..the back side followed the water, and half of the barrels floated away,I spent 2 hours chasing my barrels around the pond.
HAhaha!!!Thats good LOL'n right there!
It actually makes Much more sense the visualization you gave me on just building a frame around it now THX! ..should one come floating by me over here,my i keep it/them ??
Happy barrel hunting!
Old 02-24-2008, 08:27 PM   #24
Here are some pics I took today.
http://i252.photobucket.com/albums/h...an74/dock3.jpg
http://i252.photobucket.com/albums/h...an74/dock2.jpg
http://i252.photobucket.com/albums/h...an74/dock1.jpg
Old 02-25-2008, 05:12 AM   #25
nice method. --thanks. but so you don't have a picture of trying to tuck the barrels back under the raft, do you? or can you post that one of you and pooch chasing them around the lake? way funny.
Old 02-25-2008, 03:07 PM   #26
HEY right on with the speedy delivery on the pictures Jbfan ! !
Please also put up the "edited out" pics as Pascalle says! Don't be shy were all family here that merely want to break out in song of howling laughter is all!!
Old 02-26-2008, 09:26 AM   #27
No pics of that day. You have to use your imagination for that.
Old 03-27-2008, 06:29 PM   #28
i have 80 55 gal barrels to build a floating dock as a foundation for a house. Does anyone have drawings, plans, suggestion, links for building this float
mucco99 is offline   Reply With Quote
Old 05-05-2008, 10:10 AM   #29
Try these links.
http://www.simplicityboats.com/shantyrafters.html
http://canadianfishing.com/dock/
Lots of step by step and pictures.
txbizman is offline   Reply With Quote
Old 05-08-2008, 08:53 AM   #30
Ashley W's Avatar
Good morning everyone. I just happened to stumble across this forum and thought maybe somebody here could help me. Last week we built this floating dock:
http://i278.photobucket.com/albums/k...-5-3-08014.jpg
http://i278.photobucket.com/albums/k...-5-3-08030.jpg
We had no plans and no engineering skills, but it actually worked out pretty good. Here is our dilemma. The deck is made out of 2x6s and it is 8ft by 16 ft. We currently have 4-55 gallon plastic barrels under it. We want to be able to pull it behind a boat, up-river, and right now the dock sits too low in the water do so. We obviously know we need to add more barrels, but we aren't sure on how many and the spacing of them. As you can see we have a 7 ft by 2 ft box on the back made out of 2x6s as well so that end is a little heavier. Also, we aren't sure of which way the barrels should run. We placed them with the rounded edge forward (we thought it would be easier to pull that way), but we aren't sure this is the best way. Does anybody have any suggestions?...we have absolutely NO experience in this.
Ashley W is offline   Reply With Quote
More On This Topic
Buy pretreated wood to withstand weather related conditions for outdoor DIY (do-it-yourself) projects. Purchase lumber with tips from a home repairman in this free video on home improvements. Read More »
The lumber for a bookcase should be nice and smooth. Learn how to sand lumber from a woodworker in this free home carpentry video. Read More »
DIY wedding decorations can be as simple as a basket of fruit or as complicated as an ornate floral bouquet. Experiment using a variety of materials and edible accents to create custom wedding decorations with information from an experienced event... Read More »
Liquify is probably the most popular Photoshop tool, but did you know that you can create a similar effect in Adobe Illustrator? Illustrator's warp tool lets you bend paths around to create amazing distortions and styles. This guide will get you started... Read More »
About Cedar Lumber
About Cedar Lumber by Mark Blocker
Cedar lumber is a member of the redwood family, and it is desirable in that it deteriorates very slowly, thus making it useful for lap siding on the exterior of homes. Find out how cedar lumber is used in shims for leveling cabinets with help from a... Read More »
Floating stairs - HELP! ryandiy Building & Construction 14 07-10-2007 09:35 PM
Sag in floating floor wpr33 Flooring 1 06-03-2007 02:41 PM
Install floating floor or my doors first? jtr Flooring 3 11-16-2006 10:21 PM
Floating drywall buttjoints Webs Carpentry 11 06-09-2006 10:17 AM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 03:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
