Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-09-2005, 10:58 AM   #1
Floating Barrel Dock
Looking to build a small dock/fishing platform for my small pond. Have access to plastic 55gal drums. Has anybody built such a thing?
bruno is offline   Reply With Quote
Old 03-10-2005, 01:43 AM   #2
Contractor
I don't have time to reply tonight, it's really late. You're on the A list tomorrow.
Teetorbilt is offline   Reply With Quote
Old 03-17-2005, 09:17 AM   #3
Thanks, looking forward to a little advice.
Old 03-17-2005, 10:46 AM   #4
Contractor
bruno, How small were you thinking? A min of 8ft in any direction is about it for drums, anything smaller will be tippy. You are going to have to determine how much weight that you want it to support, a 55 gal drum displaces about 450 lbs of water which is what it takes to sink one. Ideally you would want the drums at about 1/3 of capacity unloaded.
Construction is basically the same as framing a wall. Depending on the size, I use 2X10 or 2X12 for the perimeter and through bolt them to a 4X4 in each corner. Most of what I build are work floats and I leave about a foot of the 4by standing in each corner for something to tie up with. Frame inside of the box with 2X4's just like you would a wal. The 2 on the outsides, where the drums will go should be on 24" cents., then you can fill in the field on 16's or 24's.
Next cut some saddles to fit the drums, use the same material as the frame. Cut length is to fit between the frame and the 2X's on 24's. You can calculate the radius or make a template out of cardboard and keep trimming it until it fits the drum. There will be ribs on the drum, cut to fit on one side or the other of these ribs. Fasten the saddles to the frame, install the drums and retain them with plastic strapping (I use a banding machine that I borrow). Flip it over and install your decking. Voila! Floating dock/platform.
Old 03-18-2005, 11:29 AM   #5
aka:awesomedell
Send a message via MSN to housedocs
Teetor sounds like you might have built more than a few docks. Not much call for it here in the midwest except for the occassional lake home.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 03-18-2005, 08:24 PM   #6
Contractor
hd, This is true. If I remember correctly, there a few lakes in MO.
Do any hunting? I'm always reading about the deer there, just never had the opportunity.
Old 03-19-2005, 09:38 AM   #7
aka:awesomedell
Actually I don't hunt any more, used to go deer hunting every yr, but any more there's just way too many idiots in the woods with guns durng deer season. I still take my boys rabbit & squirrel hunting, but they've all gotten about big enough to go by themselves. We do a bit of fishing when time affords, unfortunately fishing season is also the busy season & I don't get to go near as often as when I was younger and worked for someone else.
Old 01-06-2007, 09:45 AM   #8
I am an old engineer but have built several floating barrel docks. The largest one has now lasted over 15 years with essentially no maintainence. The key, form my standpoint is sealing the barrels and supporting them. I use GE silicone rubber clear and cover the bung completely as well as sealing the threads etc. I also remove the rubber gasket before sealing. I support the barrels in a steel frame either pipe or angle iron but wood will do well also as long as it does not deteriorate or move. The key is to keep the barrels secured and not moving. As far as bearing capacity, pure water weighs 8.33 pounds per gallon and the carring capacity of a barrel is this multiplied by the gallonage of the barrel. I am neglecting some very fine points such as barrel weight, water solid content etc. I try to limit my dock weight to 1/2 the barrel carrying capacity and find this works well. Good luck
Potato Chip
potato chip is offline   Reply With Quote
Old 09-21-2007, 10:00 PM   #9
I am building s floating donk on 55 gal plastic drums. It will be 8'6" wide by 16'long. Using 3 drums per each side, my question is should there be any drums in the center going lengthwise for better support.
stevn20 is offline   Reply With Quote
Old 11-26-2007, 06:11 PM   #10
BOB
Are therse barrels mounted vertically or horizontal ?
rbgraham is offline   Reply With Quote
Old 12-01-2007, 07:21 AM   #11
so-elitecrete
it was about 16x16 w/p/t 2x10 skirts & stringers 16" o/c w/X-bridging,,, hot-dipp'd galv lag & carriage bolts,,, 8 60gal apple juice pvc barrels allow'd it to float w/the deck elevation 14" above water,,, that's 12 yrs ago & its still out in front of the dock,,, never did 'tie' the barrels to the float as we left 'pockets' for them,,, did drag it onto shore prior to the lake freezing annually.
come to think of it, it was just pure guess if it'd work right or not,,, if it didn't, could've added more barrels along the ctr-line.
so-elitecrete is offline   Reply With Quote
Old 01-04-2008, 04:14 PM   #12
I read with a lot of interest the floating dock posts. Now I want to float a Gazebo. Can I assume I have to add the equivalent buoancy of the wieght two Gazebos? Does anyone know how I could calculate the weight? I would probably need to make the decking wider to make it more stable?
Eric
Eric Chalfont is offline   Reply With Quote
Old 01-04-2008, 08:42 PM   #13
Master General ReEngineer
Ayuh,......
You can float Anything you want Eric,......
In many places, Portland, Ore. comes to mind, there are Floating communities of Houses........
50 or 100 in a harbor......
Whatever you want to Float,.......Is covered by the basic rule, that every Gallon weighs 8.33lbs.(thanks potato chip)......
Every Gallon you displace will float that much weight.....
For a Gazebo I'd probably go with Steel Tubes, capped on the ends,.....
They'll give you some rigidity in 1 direction,+ your framing will carry the other.....
Old 02-07-2008, 08:49 PM   #14
What type of wood could be used to deter rotting without endangering environment?
fhill5 is offline   Reply With Quote
Old 02-07-2008, 08:52 PM   #15
This sounds like an excellent idea! What can I use nowawdays for wood that will last?
Potato Chip
More On This Topic
Pet Turtles: Basking Dock
Pet Turtles: Basking Dock by Expert Village
Basking areas, or docks, for your turtle can attach to the side of the aquarium or float in the water. Learn how to choose a basking dock for your turtle from an industry professional in this free pet care video. Read More »
Parts of an English Saddle
Parts of an English Saddle by Expert Village
Hi! I'm Kelli on behalf of Expert Village. I am going to show you my technique to saddling a horse with an English saddle. I am going to go over some of the basic parts of an English saddle. So this is our English saddle right here. This front part up... Read More »
Hi I'm Mark, I'm here with Expert Village at the Competitive Edge Cycler in Upland to explain how to buy a quality bike from a bike shop. One of the most important things about buying a bike is the fit. When you go to a bike store there will be numerous... Read More »
Hi, I'm Kelli on behalf of Expert Village, I'm going to show you my tips and techniques to saddle your horse with the western saddle. So in conclusion when you are saddling your horse to ride western, you want to make sure that you have saddle pad that... Read More »
Learn how to play the song Float On by Modest Mouse on drums in this free video series - easy drumming lessons. Read More »
Floating stairs - HELP! ryandiy Building & Construction 14 07-10-2007 09:35 PM
Sag in floating floor wpr33 Flooring 1 06-03-2007 02:41 PM
Install floating floor or my doors first? jtr Flooring 3 11-16-2006 10:21 PM
Floating drywall buttjoints Webs Carpentry 11 06-09-2006 10:17 AM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 03:10 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
