Flex Pipe And Irrigation - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-23-2014, 03:35 PM   #1
Rewards Points: 50
Flex Pipe and irrigation
In looking at some Orbit sprinkler plans, they say to connect the sprinkler heads via the use of 1/2 inch flex pipe.
Do they suggest this just because it gives you more flexibility in locating the final head position? or is there possibly some code reason?
I dont understand why you just cant go from pvc supply to a pvc elbow and then the sprinkler head, or can you?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 03-23-2014, 04:13 PM   #2
Rewards Points: 12
The flex does give you flexibility for the head placement. You can go straight with PVC. It's just harder to get the final grade right.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
digitalplumber (03-23-2014)
Old 03-23-2014, 10:14 PM   #3
Msradell's Avatar
Rewards Points: 122
Having the short section of flexible pipe also presents breaking the main PVC line if someone hits the sprinkler head hard with a riding mower or something similar. If the head is direct connected to the PVC any such blow would likely break the PVC and cause a major problem to repair.
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Irrigation tap pipe size jfrank Plumbing 10 01-27-2013 08:01 PM
Irrigation tap pipe size jfrank Plumbing 1 01-21-2013 01:42 PM
Joining 1/4" walled poly pipe IDEAS NEEDED!! CallMeChaz Plumbing 0 05-22-2012 10:04 AM
Irrigation pipe Audiotekm Landscaping & Lawn Care 1 05-23-2011 10:09 PM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
