-   -   Flex Pipe and irrigation (http://www.diychatroom.com/f16/flex-pipe-irrigation-198261/)
digitalplumber 03-23-2014 03:35 PM
In looking at some Orbit sprinkler plans, they say to connect the sprinkler heads via the use of 1/2 inch flex pipe.
Do they suggest this just because it gives you more flexibility in locating the final head position? or is there possibly some code reason?
I dont understand why you just cant go from pvc supply to a pvc elbow and then the sprinkler head, or can you?
djlandkpl 03-23-2014 04:13 PM
The flex does give you flexibility for the head placement. You can go straight with PVC. It's just harder to get the final grade right.
Msradell 03-23-2014 10:14 PM
Having the short section of flexible pipe also presents breaking the main PVC line if someone hits the sprinkler head hard with a riding mower or something similar. If the head is direct connected to the PVC any such blow would likely break the PVC and cause a major problem to repair.
