Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-05-2005, 01:13 PM   #1
Flattening dirt for grass.
I have removed the grass in my backyard. I brought in 30 yards of topsoil using a skid steer. Used shovels and rakes to distribute the dirt but it is very wavy. I have tried raking, also dragging a pallet from a rope. Tried screeding with a board but some of the areas just seem too compacted to cooperate, probably from the weight of the skid steer. Now it has set a little over a week with some rain here and there. Is there an easy way to even everything off in preparation for sod?
I'm thinking I may end up wheelbarrowing in more dirt.
Remodeling is offline   Reply With Quote
Old 06-06-2005, 02:15 PM   #2
the rental place where you got the skid steer should have an attachment for it that does just what you want. Ask them - or hire a landscaper to prepare the ground. If you'replacing sod the ground surface needs to be evn enough to provide that all sod come in full contact with the dirt. To do it right you should also lime (as needed), fertilize and moisten before placing sod. Then roll the sod and water, water, water (in the early morning not evening or night).
pipeguy is offline   Reply With Quote
Reinforcing dirt walls in crawlspace Fix-It Chick Building & Construction 8 01-13-2008 12:57 PM
Basement dirt djbauda Building & Construction 6 07-29-2007 11:26 PM
Dirt along wall in basement? Beren General Discussion 20 07-01-2007 04:53 PM
dirt driveway woes NateHanson Landscaping & Lawn Care 3 04-27-2007 02:42 PM
Looking for tips on my basement's dirt floor winky Flooring 2 10-23-2005 12:12 AM
