Fixing Up Old Sprinkler - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 12:09 AM   #1
Fixer upper guy
Rewards Points: 12
Fixing up old sprinkler
So I bought a house and the sprinkler system was neglected but appears to be mostly in-tact. One of the PVC pipes going to a zone valve appears to have popped out of the joint where it was glued. It isn't broken or anything like that. If I try to re-glue this will it hold? Or do I need to replace a big section of pipe?
teg916 is offline   Reply With Quote
Old 07-21-2010, 06:45 AM   #2
Rewards Points: 1,548
Assuming the pipe end goes far enough into the socket and the plastic parts are of the correct type (PVC, styrene, etc.) you can sand the contacting surfaces to clean off dirt and glue it back into place.
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 07:33 PM
Planning my lawn sprinkler system secutanudu Plumbing 43 08-21-2010 09:57 AM
Adding a few sprinkler heads to existing argh Landscaping & Lawn Care 9 08-03-2010 12:07 AM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
How to Look for Leaks in Sprinkler System herbolaryo Plumbing 8 06-05-2007 09:29 PM
