Fixing A Lean On My Potted Emerald Cedars - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 07:20 PM   #1
fixing a lean on my potted emerald cedars
I have 2 potted emerald cedars i just bought and re-potted into my pots.
They sit on my front porch here in Toronto Canada and are about 3 to 4 feet
tall at the moment.
They both have a small lean near their tops, should i put a small stake in the
pot and tie the tops to bring them straight?
ps. this is my 1st attempt at potted cedars and i plan on leaving these cedars
all year round on the porch which has a roof but open to the elements.
1. should i change all the soil mix every year or no?
2. should i insulate the outside of the pot in the winter?
3. should i water them when the soil has frozen?
4. i hear that the biggest damage comes from the dry winter winds and i should
just basically spay wilt-pruf on them and let them sit till warmer weather
Charlie123 is offline   Reply With Quote
Old 07-07-2010, 09:53 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
tall at the moment.
I'd try to get them into a closed in garage over the winter.
Wilt-pruf is often said to cause as many problems as it solves, and many experts recommend against it's use.
Add in a slow release plant fertilizer in early spring. No need to change the dirt, unless you want to add in some organic matter i.e.compost.
jamiedolan is offline   Reply With Quote
Old 07-07-2010, 11:04 PM   #3
Oh that wilt pruf stuff can cause problems? What kind of trouble?
How about the lean at the top of my cedars, should i stake them or just tie the top around on it's own or leave them alone?
Old 07-08-2010, 08:23 AM   #4
Since they are under a roof, are they leaning towards the sunlight? If they do, you can spin the pots every couple months so the tree grows evenly and not lopsided.
The Engineer is offline   Reply With Quote
Old 07-08-2010, 11:10 AM   #5
Exactly what I was thinking
I turn plants around in the house as they lean toweards the windows
Old 07-08-2010, 02:23 PM   #6
DIY'er
jamiedolan's Avatar
An arborist at the university of North Dakota has writen a number of times about his poor experiences with using wilt pruf. He has stated that he has seen a number of plants die when it is used, and the reason for the death / decline is not well understood. So his position is to recommend against using it. I can't remember his name at the moment, but I can dig it up if you want to read more about it.
You can steak them, but do so with care; you don't want anything that is going to grow into the tree and kill it. Using loose flexible ties, such as a nylon sock helps, the best thing to do is to make sure you monitor it and only use a steak as a temporary measure.
Notice how this small tree is tied with plant velcro straps to the bamboo stick, this is a temporary measure, that I will remove by the end of the season.
As others have pointed out, the leaning may very well be a result of your lighting situation.
The environment that plants and trees live in naturally is far different than a container. Trees normally have very wide rather than deep root systems. The soil is refreshed with nutrients from a whole manner of sources. There are many conditions that are very difficult if not impossible to emulate.
My point is just that despite your best efforts, you might only have limited success with growing trees in pots long term.
Jamie
Old 07-08-2010, 04:29 PM   #7
Thanks for the replies
I'll have to research that wilt pruf stuff more. I really wanted to leave the cedars on the porch all year to get some green on an otherwise concrete floor )
The cedars had the lean when i bought them and i thought when i re-pot them i could straighten them out from the pot but the lean remains.
So it's not a sun-tracking problem unless they had a tracking problem at the store i bought them hence i would them for awhile to see if they correct on their own, else the temporary stake with straps.
