Fix Grade In Yard - Picture!! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 06:25 PM   #1
I recently purchased a house and small amounts of water have been getting in the crawlspace. We have re-routed water from a downspout that was dropping the rainwater right near teh foundation, which may have been the main cause. However, we are debating if we should look into re-grading the yard too.
Does this look like an issue? If so, how could you do it to ensure the dirt is not touching the siding? Thanks!
donaldp is offline   Reply With Quote
Old 03-03-2010, 07:41 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Yes, it could be part of your problem but before you do anything, you should wait to see if taking care of the downspout cured the problem.
I don't see any way to bring the grade near the house high enough so that would leave the grade near the house where it is and taper it down from there.
You could also install a drain, at least along that edge of the house to drain the water that soaks into the ground away.
actually, as I look at the pic, the buried drain could be the best solution. It looks like the yard tapers down on the other side of the house. Perfect area to drain towards.
Old 03-04-2010, 12:01 AM   #3
grading
How about adding a decorative gravel type area near the foundation that can look nice, but is really for drainage?
Allison1888 is offline   Reply With Quote
Old 03-04-2010, 06:56 AM   #4
GardenConcepts's Avatar
Rewards Points: 150
You could cut a swale about 8-10' off the house directing the water around the other side. Turn the swale into a dry creek-bed by adding stone and plantings around the edges.
You could build a retaining wall +/- 18" from the foundation and raise the grade on the side away from the house to direct water away from the foundation.
GardenConcepts is offline   Reply With Quote
Old 03-04-2010, 07:52 AM   #5
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
These are all good options.
By the look of the shadow that is the dark side of the house you by the looks of the yard the grass doesn't grow all that well there. I would put a drain tile right next to the house and attach the down spout to it. Then run it down the edge of the house and strait out to the back yard. Then grade the yard away from the house and make a bit of a v from that tree on the right to the house. That will help draw the water away from the house and get it out into the back yard.
Big N8 is offline   Reply With Quote
Old 03-13-2010, 08:46 PM   #6
Professional Contractor
I would vote to install a swale and while your contractor is there have them install pipes for your leader drains and pipe them either to grade far from the house or into a drywell. Depending upon the quantity of water in your basement you may need to install footing drains and waterproof the foundation... a lot of work but not impossible.
pecord exc is offline   Reply With Quote
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Well Water ? - No water at yard hydrants... but do have water in house mntnvew Plumbing 73 01-11-2010 09:45 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Yard Advice Please - Lots of Weeds! Myrkur Landscaping & Lawn Care 7 06-15-2009 10:41 PM
My yard is ugly and I don't know an easy way to fix it. keyser soze Landscaping & Lawn Care 22 07-05-2008 03:43 PM
