-   -   Firepit made with cinderblock and stone veneer (http://www.diychatroom.com/f16/firepit-made-cinderblock-stone-veneer-70766/)
Jfuente08 05-07-2010 11:13 PM
1 Attachment(s)
I've built a circular fire pit using cinder blocks 6x8x16 and then mortaring manufactured stone veneer to the outside. Since it is such a small circle this was not an easy task, but I did finish. My question now is on putting the top cap on to finsh it off. the top cap is straight and measures 37" x 12". I'm going to have to cut it into smaller pieces and then arrange it into a circle. Is there a way to figure out how small to cut the pieces needed based on the diameter/circumference of the circle or any other way to make this easier.
GardenConcepts 05-08-2010 05:48 AM
Make a template using heavy cardboard or 1/4" plywood. Shape the template pieces to fit the top of the fire pit and transfer to your stone.
