Fire Proof Mortar - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 06:43 PM   #1
Fire proof mortar
What type of mortar should I use to build my outdoor fire pit?
deere37 is offline   Reply With Quote
Old 06-15-2011, 07:44 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Refractory mortar.
You can buy it from any brick supplier.
What about the proper brick to use? Why aren't you asking about that?
XXX
Old 06-16-2011, 10:52 AM   #3
Concrete & Masonry
Rewards Points: 568
What you want is a non-water soluable fireclay for exterior projects such as yours. I typically use Heatstop II, or Heatstop 50. Alsey also makes a comparable product. I'm sure there are others depending on region, and you should have little problem finding one at a specific masonry supply house.
jomama45 is online now   Reply With Quote
Old 06-16-2011, 10:59 AM   #4
thats just the fire box correct?
The older I get the better I was
Old 06-16-2011, 11:22 AM   #5
Concrete & Masonry
Rewards Points: 568
Correct, just the firebox in this case. On an exterior fireplace though, you want to use it on the throat, reducer, and flues as well, as they're prone to moisture as well.
"Sandy" mortar on tuck-point repair drm31078 Concrete, Stone & Masonry 7 11-25-2012 08:18 PM
Fire Pit on Gravel unclenanoose Landscaping & Lawn Care 8 10-29-2010 07:48 PM
fire resistant mortar buzzard69 Building & Construction 2 07-08-2010 11:12 PM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 04:53 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 08:57 PM
