Fire Pit Lava Rock - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 04:21 PM   #1
fire pit lava rock
Building a 36" diameter, 14" high natural gas fire pit. The fire feature I'm putting in is a round 30" ring, with 2" of reflective glass as the top surface layer of the pit (vs. having a log set).
The company recommended the 2" of glass at a cost of approx $500, and then filler for the remaining 12" below using lava rock. Every inch of filler requires 30 lbs of lava rock. I will need 360 lbs of lava rock to fill the 12" and it will cost $360.
My question: Why can't I use some kind of gravel / pebble rock for all or most the 12" of fill (at least 10" as that's about where the burner will sit)???..... and then it will be a fraction of the cost.
Thx,
Andy
Andrew Alex is offline   Reply With Quote
Old 03-15-2011, 12:45 AM   #2
Doesn't really answer your question, but if you're located near Wisconsin, I have all the lava rock you could want, for free I just want it out of my yard...
casper129 is offline   Reply With Quote
Old 03-15-2011, 05:33 AM   #3
When using other rocks they can hest up and pop out of the pit also can restrict gas flow
heatycooly is offline   Reply With Quote
Tags
fire pit filler lava rock
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Removing Lava Rock 1655graff Landscaping & Lawn Care 2 11-01-2009 10:18 AM
Building a deck on solid rock time2scream Building & Construction 3 03-05-2009 07:45 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
