Fire Pit , Circular Block Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 09:04 AM   #1
Fire Pit , Circular Block help
Where can I find circular block with a circumference radus for a 36 inch fire pit. Most seem to be made for a 30 inch inside diameter fire pit.
Thanks Woftam
woftam is offline   Reply With Quote
Old 08-14-2010, 11:07 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
why not just use fireplace brick for the inside? you can make any ID you want
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-14-2010, 04:11 PM   #3
Household Handyman
Rewards Points: 1,408
If you are thinking of using those decorative cast concrete blocks for a fire pit--DON'T. The heat will cause them to crack, and soon. Additionally the mortar used for a fire pit is different that mortar used for just laying block or bricks-I know from bad experience. I wound up finding some really old brick to make a fire pit, or burn pit for yard debris, and used the proper mortar the second time around. So far it's doing really well. David
circular fire pit paver patio - what to use/how to slope durkpiet Landscaping & Lawn Care 0 05-27-2010 11:43 PM
Fire Block This HooKooDooKu Building & Construction 3 03-02-2010 01:47 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Fire Pit Block JackOfAllTrades Landscaping & Lawn Care 13 03-24-2009 10:01 AM
How best to block up a chimney hole when taken fire place out AMT33 Building & Construction 3 03-04-2009 04:57 PM
