Finding Property Lines - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 07:08 PM   #16
Rewards Points: 5,336
There should be a copy of the survey at the local Building Dept. Get a copy and bring it home.
Ron
Old 08-07-2008, 02:21 PM   #17
You may be able to find the corner "marker" by measuring . But if it was me I'd find out what the street R.O.W. (right of way) is and measure from the center line of the nearest cross street center line. To do this find out what the R.O.W. is and half this and measure from the center line.Then add up the lots along the street to get to your starting point. This will be your first corner from the cross street.
Now you should put you very close to the corner. Take a square end shovel and take about an inch off the top at a time.
If this subdivision has been laid out in the last twenty years the corner markers should still be there.
By no means should you put in corner markers unless you find the originals and place the new ones next to the originals. You could be prosecuted for this as you aren't a licensed surveyor.
I ran a survey crew for over twenty-three years.
Bama4555 is offline   Reply With Quote
Old 08-07-2008, 03:14 PM   #18
concretemasonry's Avatar
Rewards Points: 2,578
Not all streets are built on the center line of the R.O.W. Sometimes, they are offset because a possible future lane/width. - I lived on one.
concretemasonry is offline   Reply With Quote
Old 08-07-2008, 05:18 PM   #19
The power pole is probably at one corner.
There might be something about not having your neighbor's power lines over your property, at any point.
The iron posts that mark the corners might be two inches down, so before you use the metal detector scrape off some sod where you think the posts might be.
How Do I Install New Duct Lines For My Finished Basement? luweee HVAC 17 01-12-2008 04:01 PM
I want to cut lines in my driveway - am I insane? <pics> joeyboy Building & Construction 12 11-28-2007 02:40 PM
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 06:50 AM
property lines elementx440 Building & Construction 4 03-21-2007 11:18 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
