Filling Space Where Pool Once Was (above Ground) - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By de-nagorg
Old 06-21-2016, 10:48 AM   #1
Filling space where pool once was (above ground)
Hello All! I hope I am posting this in the right place. I had a pool back here and now I have a hole. I have a party in a few days and need to make use of the space. Can you guys provide a quick, easy DIY cheap solution to this problem? We tried filling it with mulch but it just looks like dirt now. We would like to make it a usable space to put tables in. We also tried laying down astroturf and it was pretty tacky.
MrNYSE is offline   Reply With Quote
Old 06-21-2016, 10:48 AM   #2
Re: Filling space where pool once was (above ground)
Old 06-21-2016, 11:01 AM   #3
Rewards Points: 658
It couldn't be done in a couple days, but a round deck might be nice.
gma2rjc is offline   Reply With Quote
Old 06-21-2016, 11:08 AM   #4
Just a temporary fix works. I am only using it for a 1 day
Old 06-21-2016, 12:48 PM   #5
Rewards Points: 2,360
Several sheets of 3/4 inch plywood, laid out and primer painted.
Should suffice as a quick cover-up until a real paver patio can be installed.
ED
r0ckstarr likes this.
de-nagorg is online now   Reply With Quote
Old 06-21-2016, 12:58 PM   #6
is there a thinner cheaper plywood that would work and withstand weight on it?
thanks
Old 06-21-2016, 04:52 PM   #7
If you are willing to do a little shovel work, leveling and smoothing the dirt.
3/8 ply would probably hold up well, just don't put a lot of LARGE people in one place on it.
You could duct tape the seams to keep the sheets together, and have a fairly flat surface to use tables and furniture on at least temporarily.
Just remember that this is temporary, and get a real patio built later.
ED
Old 06-22-2016, 02:46 PM   #8
r0ckstarr's Avatar
Rewards Points: 2,060
What are your plans for the hole after the party?
r0ckstarr is offline   Reply With Quote
Old 07-05-2016, 08:17 PM   #9
That would be a perfect spot for sand and a fire pit.
dc300m01 is offline   Reply With Quote
Long run of conduit for underwater pool light/switch BrandonC_1972 Electrical 1 06-25-2014 05:54 AM
Above ground pool removed, now what? AnginFL Landscaping & Lawn Care 7 03-23-2014 09:20 AM
Bonding Above Ground Pool mboyer Electrical 1 04-30-2012 12:36 PM
Reserved space for above ground pool free of weeds Girly_girl Landscaping & Lawn Care 6 10-19-2011 05:22 PM
Above ground pool, required receptacle. whatrymes Electrical 22 08-18-2011 07:22 PM
