Filling In Drainage Ditch - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-09-2007, 12:02 AM   #1
Filling in Drainage Ditch
Hello all,
I am an owner of a new "patio home" in a fourplex, our neighborhood is old and the streets are narrow. Even with all the new construction changing the neighborhood, the city does not see fit to widen the streets so there is limited street parking!
There is a drainage ditch that runs next to our shared concrete driveway, directly in front of my patio home. I need some advice on how to have it filled in to create a parking space and what the average cost would be. Do I need to have them use a conduit and dirt? Or if this is even possible?
Thank you!
apham is offline   Reply With Quote
Old 10-09-2007, 12:44 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Contact the city street department for their specs. You should be able to fill the drainage ditch after using an approved-sized drain line of tile (concrete sections, etc. or whatever they allow). They might do the work at cost, or they may allow you to do it. You will need a permit and inspection in any case, I would assume.
Good luck!
Mike Swearingen is offline   Reply With Quote
Old 10-18-2007, 03:47 PM   #3
Mod / ArchiBuilder
Cole's Avatar
Where are you located?
Cole is offline   Reply With Quote
Retaining wall drainage werc Landscaping & Lawn Care 12 05-23-2008 10:43 PM
8 foot perimeter ditch for home defense silverfrost1 Building & Construction 5 09-05-2007 04:43 PM
Building a drainage ditch get outside Landscaping & Lawn Care 5 05-15-2007 02:44 PM
Drainage Ditch Issues........ Alan Landscaping & Lawn Care 2 06-23-2006 11:45 AM
