Fill Over Wood Chips? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 01:00 PM   #1
Amateuralex's Avatar
Rewards Points: 270
fill over wood chips?
Howdy folks. We had a big pine removed, and they left a fair amount (half a cubic yard?) of wood chips where it was. The tree sat in a depression, and now we want to fill it in and grass it over. Probably 2 cubic yards of soil required for that. Can we just dump soil right on top of the wood chips? Is there some problem I am not forseeing?
Amateuralex is offline   Reply With Quote
Old 08-28-2012, 01:39 PM   #2
A Little Of Everything
Rewards Points: 1,364
Spread the mulch out a lot before covering over it, because it will decompose. Also, the soil itself will settle quite a bit. So plan on adding more soil next spring.
DrHicks is offline   Reply With Quote
Old 08-28-2012, 01:48 PM   #3
Rewards Points: 270
OK cool, so it's just a bit of settling to worry about, perfect, thanks a ton.
Old 08-30-2012, 02:03 PM   #4
Too Short? Cut it Again!
The decomposing material will draw nitrogen from the soil and plants for the process so plan on compensating for that. You need to monitor Ph as well.
And plan on settling for years to come if this was a large old tree.
The Following User Says Thank You to user1007 For This Useful Post:
Amateuralex (08-30-2012)
Old 08-30-2012, 05:09 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 498
many of them
Old 08-30-2012, 08:51 PM   #6
Bombastic Idiot
notmrjohn's Avatar
Originally Posted by chrisn View Post
many of them
And some more after that. I Have um come back and rake it out, or you rake it out and use it for mulch and save th3 or 4 bucks a bag.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 08-31-2012, 03:54 AM   #7
chrisn's Avatar
Rewards Points: 498
raking out the chips would be the way to go
Old 08-31-2012, 05:25 AM   #8
But you will only get as much as the stump grinder chewed up. You will still get settling for years to come.
Old 08-31-2012, 04:55 PM   #9
chrisn's Avatar
Rewards Points: 498
very true
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Is this normal??? Exposed wood near foundation of house? simiesue Building & Construction 19 01-04-2012 10:01 PM
how to brace wood walls for fill dirt Chuck Atkinson Building & Construction 12 10-01-2010 02:42 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
