Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-14-2011, 08:25 AM   #1
Question
Field Stone and Mortar Wall, will it be stable?
I built a small 2 meter by 1.2 m raised garden bed, it is .7 m in height. I plan to fill it with gardening soil and move a bunch of raspberry bushes into it (with a bamboo lattice). Hopefully the raspberries will be easy to harvest and will stay contained in the raised bed instead of spreading through the yard.
That's a poor picture but you get the idea. I built the thing over the course of a Sunday from field stone and two bags of mortar cement. It has no base, I just cleared out the grass and the entire thing rests on dirt. Will it be strong enough to contain the three or so cubic meters of dirt dirt and not collapse or explode from hydraulic pressure?
If I were following proper procedure I probably should have first built a base... I know. Altogether though if a field stone + mortar wall holds up it's quite a value. The stone was free and the two bags of mortar cement cost $8 total. That's as much as just nine or ten stacking blocks at home depot! Any resources on how to build with field stone for future reference, so I build future projects properly??
EDIT: In the future, if I build any more such field stone projects, I think I will cap the top layer off with a more expensive nice looking stone. If this works it will give rustic but nice look at much lower cost than using prefab concrete block or pre-cut stone from HD.
NorskeDiv is offline   Reply With Quote
Old 07-14-2011, 08:51 AM   #2
Super Moderator
Does it freeze and thaw where you live?
That doesn't look very substantial--however---it's done and you don't have a lot of money into it---
so , filler er' up! See how she works.---Mike---
Old 07-14-2011, 08:53 AM   #3
Yeah, it freezes a few times a year. Sounds like you at least think it has a chance of staying together, so I guess it's worth a try!
Old 07-14-2011, 09:12 AM   #4
Super Moderator
I like the rustic look---my own attempts at masonry have been rather humble---It's an art to lay stone well.
Old 07-14-2011, 11:18 AM   #5
For $8 you have what you have! For what it's worth I think it's surprisingly attractive. I could wish you'd poured a footer. :-) It won't stand the test of time, but for now you've got a real bargain. You might consider a peat/topsoil/mulch mix from your local landscaping store.. It's a lighter-weighing fill and great for gardens.
Minich is offline   Reply With Quote
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 12:13 PM
Faux stone exterior wall by pool - advice please! t3w Building & Construction 5 03-02-2010 09:54 AM
Stone wall problem with mortar weberus3 Building & Construction 22 01-06-2010 09:06 AM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 05:03 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
