Fertilize In The Heat? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 08:51 AM   #1
Rewards Points: 77
Fertilize in the heat?
Might be a dumb question but I'll ask anyway. Its about time to fertilize my Bermuda grass here in NC, but I was wondering with the excessive heat we get this time of year if it would be an issue? The lawn gets enough water. Go ahead and feed?
asbury park is offline   Reply With Quote
Old 08-04-2012, 08:59 AM   #2
Too Short? Cut it Again!
Bermuda needs regular feeding. I sought to give my bermuda lawn in N California one pound of nitrogen (first number of the three number NPK ratio on a bag of fertilizer shows how much nitrogen is in the sack) per 1,000sf per month during the growing season. That may be overkill but was the formula taught at the time. I used fast acting, not timed release turf food and every other month just got nitrogen.
Assuming you are sure you can keep up with watering (and mowing in the heat) you should be alright feeding the turf. If you want to play it safe, you might actually cut back on the nitrogen a bit. Just be sure to water it in thoroughly after application when it is hot like this. You might also consider putting half the amount you normally would on now and seeing how it goes. Repeat in two weeks.
Old 08-04-2012, 09:08 AM   #3
Rewards Points: 77
Sounds good. Thanks
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
