Fence Problems-Cement Or No Cement - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-27-2007, 06:47 PM   #1
Angry
Fence problems-Cement or No Cement
I had a 6ft high 48 foot long cedar dog eared privacy fence installed with PT post. The installer gave me an estimate of $960.00 There add said they where 4th generation fence Installers. After less than 6 months a strong wind came through our area and the fence blew partially over. I was originally told that the post would be cemented in but no mention of it was on the estimate nor did it say it would not be cemented in. I had assumed that they where a professional company and what he told me about the cement was standard fence building practice for a fence this high. When I inspected the hole left by the fence bent over I could see there was no cement in this hole. They sent out a person who said it was because of soft ground. (like itís my fault) and gave me an estimate to fix it for $250.00. This included cementing in the post which that said had already been done. When I balked at paying this they agreed to come out and do it for free. Less than two months after there repair it started to lean. I dug down a foot on the post most bent over by the wind and found again no cement. My questions are 1. Is it standard practice to cement in post for a fence this high? 2. If not wouldnít a professional know that it needed to be cemented in (due to soft dirt) and recommend it at additional cost. 3. Am expecting too much? (My fence not to lean) I have written them and had no reply as yet. I am considering going to the BBB but if they did every thing correct I wonít bother. Your opinion is appreciated. Thanks in advance.
WBMill is offline   Reply With Quote
Old 04-27-2007, 09:34 PM   #2
Contractor
Brickie's Avatar
Rewards Points: 79
Did you have a written contract with the people that installed your fence?
Did you file any claim with your insurance company when the heavy winds knocked your fence over?
Brickie is offline   Reply With Quote
Old 04-28-2007, 09:16 AM   #3
Contract -Yes Insurance -No
Yes. As I said in the original post it did not mention there would or would not be cement. This understanding was from his original visit when he expalined what was going to be done. As for insuruance I never thought a filing a claim but I have a $500 dollar deductable. I don't want to pursue this if I just expected too much. I know a verbal agreement is worth nothing in a court of law or arbitration. I have installed 3 ft high fence myself and did not use cement execpt when I put in the gate post but this is 6ft high with much more weight and no way for air to go through. I needed it installed fast and soon and depended on a profesionals judgement as to what was correct. I would have cemented it in just because I am not knowledgeable on fences.
Old 04-28-2007, 09:16 AM   #4
Old 04-29-2007, 09:02 AM   #5
cost of fence
I don't know where you live. here ( one of the most expensive real estate areas in the country) that is a pretty low price for cedar installed, I think; I would hope I never have to pour footers , install and supply cedar for such a price- am about to do similar section of fence - hope to get way over $2000. - haven't priced the details yet.
When my customer asked if I could hold up the fence temporarily, I hammered in the green metal fence stakes and lag-bolted them to the posts- I don't know how many years that would last before rusting in the ground, and certainly mars the original appearance, but you could do it yourself till you figure out what to do next.
former artist is offline   Reply With Quote
Old 05-17-2007, 11:42 AM   #6
This is why I am always present when ANY work is being done at my home. No surprises.
tbone2004 is offline   Reply With Quote
Old 05-17-2007, 12:24 PM   #7
Rewards Points: 264
I saw an episode of This Old House where they installed a fence. I remember they stated: As long as the post is close to 3' below grade, there is no need to cement.
Jeekinz is offline   Reply With Quote
Old 05-17-2007, 05:39 PM   #8
Problem solved. Post cemented.
Good news the company came and looked and cemented in my post. I not sure if they admitted their mistake or just wanted make me happy.
The only reason I didnít do it myself is I was depending on the experience of a professional to make the correct choices. Cement needed, cement not needed type post, material etc. I only received part of all the information. If there was a miscommunication it was on the part of the professional to his customer. To me a fence should not fall over months after it was installed.
Thanks for the follow up problem solved!
Old 06-17-2007, 03:36 PM   #9
Similar problem
I bought a home that was only two years old and had a six foot wooden fence around it. The back portion had fallen down and l had to replace it. Later one of the side sections fell down and I replaced it. What I found in both cases was the posts were two feet in ground but only the lower foot was set in cement, the wood rotted away in the one foot portion above the cement. When I replaced the posts I poured cement to 2 inches above surface and finished the cement off tapering away from the post so water would not collect around them. The fence was built by a local contractor for the developer building the homes. There have been a number of fences in the area blow over. Best idea is to be sure the posts are fully set in cement.
dwayne is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Foundation Problems LeahWood Building & Construction 13 08-01-2007 02:12 PM
fence problems? composite decks? maml247 Landscaping & Lawn Care 6 03-29-2007 03:10 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
