Fence Post Replacement In Existing Concrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 09:42 AM   #1
Fence Post Replacement in Existing Concrete
I am trying to replace one fence post in an awkward area between a garage foundation and a sidewalk. The old post was completely rotten and I did not want to break out the old concrete around it due the adjacent slabs and foundations. It appears that the sidewalk was poured the same time as the post was installed. I removed the old rotten post to a depth of 12", but the new treated post is a very tight fit. Should I just try to beat it it or are there some other tricks I can employ (maybe dry out the new post to shink it)? This post only supports a 1' section of fence and functions to latch the gate to. Thanks!
ggunder is offline   Reply With Quote
Old 11-26-2011, 09:45 AM   #2
Civil Engineer
Rewards Points: 4,854
If you need to shave the post down to make it fit, you can use a rasp, draw knife, plane, or wood file to do so.
Old 11-26-2011, 02:00 PM   #3
I was brave and used a 12 pound sledge. It took about 24 whacks to drop it to the bottom of the hole. It is plumb and very solid in addition to saving all of the treated wood. Thanks!
Old 11-26-2011, 02:09 PM   #4
concretemasonry's Avatar
Rewards Points: 2,626
Sounds like a good solution. The concrete provides the lateral strength an you got the wood and concrete to work together.
Dick
concretemasonry is offline   Reply With Quote
Old 11-26-2011, 09:21 PM   #5
Msradell's Avatar
Rewards Points: 258
It's obviously too late now but was the bottom of the hole for the post concrete or gravel? If it's concrete that was a major part of your problem because the water couldn't drain from around the post. If you embed a posting concrete the bottom definitely needs to be open, preferably sitting in a gravel bed.
Msradell is offline   Reply With Quote
Post in concrete and getting plumb. fabian Building & Construction 29 08-07-2011 08:16 PM
How to replace a loose fence post preciouschristy Building & Construction 2 05-14-2011 05:06 PM
Re-using post holes in concrete philS Building & Construction 8 05-04-2009 08:15 AM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 01:09 PM
