-   -   Fence Post Replacement in Existing Concrete (http://www.diychatroom.com/f16/fence-post-replacement-existing-concrete-124629/)
ggunder 11-26-2011 09:42 AM
I am trying to replace one fence post in an awkward area between a garage foundation and a sidewalk. The old post was completely rotten and I did not want to break out the old concrete around it due the adjacent slabs and foundations. It appears that the sidewalk was poured the same time as the post was installed. I removed the old rotten post to a depth of 12", but the new treated post is a very tight fit. Should I just try to beat it it or are there some other tricks I can employ (maybe dry out the new post to shink it)? This post only supports a 1' section of fence and functions to latch the gate to. Thanks!
Daniel Holzman 11-26-2011 09:45 AM
If you need to shave the post down to make it fit, you can use a rasp, draw knife, plane, or wood file to do so.
ggunder 11-26-2011 02:00 PM
I was brave and used a 12 pound sledge. It took about 24 whacks to drop it to the bottom of the hole. It is plumb and very solid in addition to saving all of the treated wood. Thanks!
concretemasonry 11-26-2011 02:09 PM
Sounds like a good solution. The concrete provides the lateral strength an you got the wood and concrete to work together.
Dick
Msradell 11-26-2011 09:21 PM
It's obviously too late now but was the bottom of the hole for the post concrete or gravel? If it's concrete that was a major part of your problem because the water couldn't drain from around the post. If you embed a posting concrete the bottom definitely needs to be open, preferably sitting in a gravel bed.
