Fence Installed On The Ground?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 04:25 PM   #1
Jack of all-master none
Fence installed on the ground??
I am concerned, I contracted with a small fence contractor to install 200 feet of fence on my property. The fence consists of posts and rails with boards set on either side of the rails.
My concern is that even though he used pressure treated lumber throughout setting the post in concrete, the 80% of the vertical boards are in contact with the ground. I feel that I don't care what the boards are treated with, they should not be in contact with the ground. The water will wick up into the wood. I am right?
RallyRed is offline   Reply With Quote
Old 08-27-2012, 04:29 PM   #2
Rewards Points: 13,300
Yes, the boards are not going to be below ground rated, only the post are.
Old 08-27-2012, 07:45 PM   #3
kwikfishron's Avatar
Rewards Points: 202
Nothing a little shovel work shouldn't fix.
kwikfishron is online now   Reply With Quote
Old 08-27-2012, 08:04 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
i like to see the pickets set about 3-4" above grade. It makes weed trimming much easier. The posts should not be set in concrete also. Although many would beg to differ im sure, a properly tamped soil around the post will be sufficient.
Millertyme is offline   Reply With Quote
Tags
fence , ground contact , pressure treated , rot , wood
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
MC w/ground loading from BX w/o ground amakarevic Electrical 27 04-03-2012 09:33 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 07:34 PM
home grounding problem smoke-wagon Electrical 7 06-25-2009 04:07 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
