Fence Came Out Of Ground - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 01:52 AM   #1
Question
fence came out of ground
At the back of my friends house his fence is partially fallen over on an angle. The concrete is still attached to the wooden fence post. Could my friend just get some ready mix concrete and pour it into the partially available hole then push the fence back up so it is not on an angle anymore? Is is okay to add new concrete to existing concrete that is years old?
For reference, here is a photo(not my friends) of a fence that has fallen(fully not partially) that still has the concrete attached to it:
http://reliefvolunteers.com/11282008022.jpg
ryan14 is offline   Reply With Quote
Old 10-27-2010, 07:57 AM   #2
Professtional Remodeler
Yes you could, but the better way to do this would be to buy a new wood post ( Im assuming it is a wood fence) place it in the hole, which by the way should be about 36" down and install blue stone around the post. Than attach the fence. This allows for drainage around the post and will not rot the post.
valueremodeling is offline   Reply With Quote
Old 10-29-2010, 10:52 AM   #3
Rewards Points: 150
I think replacing the post is a given but this sounds like frost heave not rot. So unscrew fence panels pull out old post dig hole 36" at least then set new post in concrete as for drainage meh.
STL B. is offline   Reply With Quote
Old 10-30-2010, 07:43 PM   #4
The fence posts have to be below the frost line.
Oops! is offline   Reply With Quote
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-04-2010 11:44 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 02:36 PM
