Fake Rock For Retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-07-2008, 01:14 PM   #1
Rewards Points: 77
Fake rock for retaining wall
I want to build a retaining wall in my backyard but don't want to pay for real rock or the bricks. I have seen some places that have fake rock that looks like some sort of hard plastic or composite. It looks real but if you knock on it it almost sounds hollow. Does anyone know how much this costs and where to buy it? I haven't seen it for sale anywhere.
epeterson777 is offline   Reply With Quote
Old 06-07-2008, 01:51 PM   #2
concretemasonry's Avatar
Rewards Points: 2,642
How much soil do you want to retain?
Plastic sounds like a poor solution if you want it to be permanent.
Dick
concretemasonry is online now   Reply With Quote
Old 06-07-2008, 02:37 PM   #3
Rewards Points: 77
The wall will be about a 1 to 1.5 feet tall. So it'll be holding back a fair amount of dirt. My plan was cut fence posts in half and dig them in and attach plywood to the fence posts. Then I wanted to attach the fake rock directly to the plywood. So the wood would actually be doing the support. I would probably use some sort of real rock for the capstones.
Old 06-07-2008, 03:02 PM   #4
Rewards Points: 1,232
Fake rock costs more than real rock, so your idea is based upon a faulty premise. And the "design" of a plywood retaining wall covered with fake rock would be doomed to certain and rapid failure.
Tscarborough is offline   Reply With Quote
Old 06-07-2008, 03:18 PM   #5
Rewards Points: 77
How much does manufactured stone usually run? Mine needs to be about 25-30 feet long and a little over a foot tall. If I use those generic looking bricks that Home Depot sells it will cost me over $500. I live in Colorado so I could go buy real stone for cheaper than that, but real stone will leave a lot of gaps. I just like the clean look that fake manufactured stone has.
Old 06-07-2008, 05:23 PM   #6
5-7 bucks a SqFt., and you will need to buy CMU to adhere them to, not some contraption of plywood.
Old 06-07-2008, 10:03 PM   #7
Rewards Points: 77
Where can you buy it at?
Old 06-07-2008, 10:53 PM   #8
What part of Colorado are you in?
Old 06-08-2008, 06:17 AM   #9
Rewards Points: 77
NE Denver metro.
Old 06-08-2008, 09:30 AM   #10
Visit Robinson Brick. They have fake stone/real stone and excellent brick and have a nice showroom.
Old 06-08-2008, 11:19 AM   #11
Rewards Points: 77
Thanks for the info. I looked at there website and that is exactly the type of stuff that I like (the Robinson Rock). I'll have to head down there one of these days to price it out.
I am also finishing my basement and the "thinrock" brochure they have is giving me some awesome ideas.
Old 06-08-2008, 09:16 PM   #12
wall
I think it may work for foot high wall.
Just take care of digging 8-10 inches deeper and feet wider, put gravel bed underneaths and around bottom part, don't put wall vertically-lean it towards higher level and backfill it well with gravel. Plywood has to be moisture protected as well from other then concrete stones side.
taty is offline   Reply With Quote
Old 06-09-2008, 11:17 AM   #13
Registered User
Termite's Avatar
Plywood isn't something that should be incorporated into a retaining wall, or even a decorative non-structural wall. Wood, for that matter, isn't really a great long-term option at all.
I think you're on the right track with CMU blocks and an applied rock face. Be sure that you place an appropriate footing with compacted AB3/road base or concrete, or your wall won't last long at all.
Old 06-09-2008, 11:49 AM   #14
rock over block
Just found that my neighbors did something similar - but they used thin- veneer rock over the block wall. looks real!
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
