Extracting a broken sprinkler riser?
I picked up a extractor tool to get the broken riser out of the pipe but all it is doing is scraping out the riser rather than sticking into the riser and grabbing it. Any suggestions on how to get the broken riser out?
Thanks, SCS |
What part are you trying to get out? Most sprinkler head tools go into a slot in the top, turn a 1/4 turn and catch on a lip to pull up on.
The threaded riser snapped off in the pipe. Home depot sold me a pipe extractor that is supposed to catch the inside of the pipe turn it counter-clockwise but all it is doing is scraping out the pipe and that will eventually leave me a smooth surface where the threads meet. I hope I'm explaining this correctly.
Sounds like what mechanics call an "easy out." It bites into the broken pipe so you can turn it to the left and unscrew the broken piece out. It shouldn't damage the threads unless you are that far down and keep trying to get a bite and just wear all the pipe away. Try tapping the tool into the broken piece to get a little better bite. I know this will probably be difficult because the line will give under you a little but worth a try. It would probably help to put something under the supply line to support it.
| All times are GMT -4. The time now is 07:38 PM. |
