Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-13-2007, 02:17 PM   #1
Send a message via Yahoo to Toady64
Arrow
Extending a patio...
Hello - I need to pour concrete into an area that goes under a door threshold (for a screened in porch) and is also attached to a brick patio. I believe I've read enough to do this, but now we (she) wants to include a landing area with 4 18" square brick pavers outside the doorway. In all, the area is about 16 sq ft. The $1M question is, how do I get the pavers at the proper height for the doorway? I don't think I can raise them up with sand before pouring concrete. The sand would 'eak' out, loosen the pavers and make the small concrete pad too thin. Any advice would be welcomed. Thanks.
Toady64 is offline   Reply With Quote
Old 10-18-2007, 04:43 PM   #2
Mod / ArchiBuilder
Cole's Avatar
I am not fully understanding.
Can you sketch what you are trying to accomplish.
Cole is offline   Reply With Quote
Old 10-27-2007, 08:42 AM   #3
so-elitecrete
form & place the bagg'd crete under the threshold, remove the form, add gravel, compact, place h/d pavers, & brush in holding sand ?
don't forget rebar & do NOT make your threshold pour less than 8" x 8" or be prepared to have it crack in the middle .
so-elitecrete is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 02:30 PM
