-   -   Ewe Bush Removal With Skid Steer (http://www.diychatroom.com/f16/ewe-bush-removal-skid-steer-137150/)
dstorjoh 03-15-2012 02:13 PM
I am going to try to remove these bushes with a skid steer. I was going to chain the bush branches all together to the loader and lift slowly. I am somewhat skeptical of this plan due to the fact that the bush branches don't all connect to one main branch (see image, sorry bout the quality). My thought is that it may rip through each branch ultimately leaving me with a stump. Has anyone done this? Is there a better suggestion?
http://i1050.photobucket.com/albums/...d/DSC00002.jpg
user1007 03-15-2012 05:32 PM
You should be able to pull it out but not by attaching a chain above the surface. You will need to dig down until you can grab a solid chunk of the stump/taproot structure. It may be that the back off does split from the front. Just repeat the process. Go slow and pull. Don't gun the machine and try to yank it out.
Also looks like you have a slab near? Keep an eye on that and stop if you see it starting to heave the slightest bit. In which case, you may have to dig it out or at least dig deeper and cut the roots under it with a chainsaw.
dstorjoh 03-19-2012 11:36 AM
This is great information. thank you.
Bondo 03-19-2012 07:25 PM
Ayuh,.... Dig down a couple inches to wrap yer chain around the Whole plant at the base,..
Use a Slip hook, not a Grab hook,...
After hookin' the chain 'round the base of the Whole plant, pull Back, away from the house, Not Up...
dstorjoh 03-19-2012 09:52 PM
I had always heard "pull up" on the bush. Why do you suggest pulling out and away from the house? Aside from decreasing the chance of hitting the house.
Bondo 03-20-2012 05:24 AM
Ayuh,.... Because I've found it Works better, 'n the chain with a slip hook will tighten, rather than pull off the bush...
cleveman 03-20-2012 10:35 PM
For your information, a ewe is a female sheep.
The plant you have photographed is a yew.
A ewe bush is rarely discussed. I think maybe only in Montana, Wyoming, maybe Utah.
user1007 03-21-2012 06:01 AM
They are used interchangeably in the classic song though...
"It Had to Be Ewe/Yew"
chrisn 03-21-2012 04:27 PM
wild wonderful west virginia:yes:
