Electric Starter - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 04:17 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
electric starter
I have an Ariens 824 with an electric start. When I press the electric start it sounds like it just turns and not make contact. So, I can't start it with the electric starter but can pull start it. Can I just replace the box on top with the plug, or do I have to replace the whole thing that goes into the engine.??
Barry
Barry J is offline   Reply With Quote
Old 01-22-2011, 04:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 660
Ayuh,... From your discription, the switch is workin' just Fine...
The starter, mounted to the motor, sounds like It's the Problem....
Probably the bendix drive end is stripped, or broken...
Take it off, 'n have a look...
Old 01-22-2011, 04:27 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Ok I just watched a video on how to take off the starter..seems pretty easy...how can i check if I need to replace the starter or just fix it somehow??? And where would be the best place to pick one up, on-line is an option, since I can still pull start it, I'm not in a terrible rush.
thanks
Barry
Old 01-22-2011, 04:32 PM   #4
Bondo's Avatar
Rewards Points: 660
Ayuh,... Look it over for whatever looks outa place,...
stripped gears, bad teeth, worn bushings, Whatever...
bench test it, whatever...
DIY'ing is just figurein' out, what Ain't,...
Google usually brings up anything you need,... times a Thousand...
Old 01-22-2011, 04:36 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I'm gonna look at it tomorrow, if I go out to the shed now, I'll be working in the dark soon, I'll look tomorrow...thanks for the info
Barry
Old 01-22-2011, 04:56 PM   #6
Bondo's Avatar
Rewards Points: 660
Barry
Ayuh,.... That's why Tom Edison invented the electric lightbulb,...
Old 01-22-2011, 04:58 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Hey Bondo
You got Moxie as your Avatar....you don't drink that stuff do ya?
tcleve4911 is offline   Reply With Quote
Old 01-22-2011, 05:13 PM   #8
Bondo's Avatar
Rewards Points: 660
Originally Posted by tcleve4911 View Post
Hey Bondo
Ayuh,... I buy 10 cases or more whenever passin' through Gorham Nh. runnin' between here, 'n Old Town...
Once, or twice a year...
Ariens Sno Blower Electric Starter problem bushy Automotive Repairs 1 11-28-2010 01:15 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
Toro 521 electric starter repair hwm General DIY Discussions 4 12-12-2007 10:28 PM
