Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-14-2010, 10:42 AM   #16
It was a dark and stormy
Yoyizit's Avatar
Electric pole tree saw
Originally Posted by canyonbc View Post
Yes, a lot of them do. It is sad, it is a great industry can not really be too safe.
I am in the tree care industry professionally, and let me tell ya the Big Shot, wow they work great, I can shoot over branches over 80' with enough under brush clearance.
Did you try the cradle throw??? or google search how to throw a throw weight.
I like to pinch up about 3 feet above the throw weight and make a slip knot. Then I toss it back and forth like I was going to toss you a bean bag, and then bam on up.
If you like to read and like a good over few I would highly recommend two books.
Tree Climbers Companion (Shorter)
(One of my favorite books) - Fundamentals of General Tree Work by G.F. Bernak
Hope this helps.
It was some time ago, but I got those books and videos out of the library.
Finally I bought a body harness and lanyard from Grainger; didn't get the fall arrester.
And I just got the light weight elec. chain saw from Remington; have had a gas saw for years now.
I wouldn't mind working for free as part of a ground crew but it's like selling iceboxes to Eskimos. I think it's because somehow I've gotten, and look, too old.
Old 01-18-2010, 08:41 PM   #17
dIYHell
you can always just use this as a solution with a really long pole http://thereifixedit.com/2010/01/18/...le+Feedfetcher
rocketdoctor is offline   Reply With Quote
Old 01-19-2010, 01:13 AM   #18
Haha,
Well I dont think I would pull that out on of my job sites but if it works it works
If you have more then a few, they have fiberglass 6' or 8' ft poles that link together like a pole brush and stick and have specific heads that attach on to the end a little more stable then the posted picture but hey let me tell you before I entered the tree care industry professionally I have used your method many of times with good success on small branches
canyonbc is offline   Reply With Quote
Old 01-21-2010, 11:03 AM   #19
Lightbulb
Originally Posted by Yoyizit View Post
I have a small branch 25' directly above that is otherwise inaccessible and I'm considering fastening my Remington elec. saw to a pole.
What do you use for a pole?
Is this distance practical?
How do you work the oiler?
I found an electric pole saw that reaches to 30 feet. It's called the "extended reach pole saws" Google it up and see if that helps.
TheGidna is offline   Reply With Quote
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 04:23 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
