Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-18-2010, 02:13 PM   #16
DIY'er
jamiedolan's Avatar
Electric chainsaw - is this a good idea?
Originally Posted by Red Squirrel View Post
I was cutting down a tree for my parents with my buck saw while the neighbor was trying to get his chainsaw started, then he decided to use a sawzall, and wow, does that ever go well. I would actually buy a good sawzall and some long blades over a chainsaw just for the simplicity and convinience - no gas or oil to worry about.
Bosch makes the best sawzall blades that I have found:
http://www.boschtools.com/products/a...l.aspx?pid=293
Milwaukee makes a pruning blade:
http://www.amazon.com/Milwaukee-48-0.../dp/B000E8SZSC
I've used both for pruning / large branch cutting, and I think the bosch blades last the longest and make very good cuts.
Jamie
jamiedolan is offline   Reply With Quote
Old 07-21-2010, 09:53 PM   #17
It was a dark and stormy
Yoyizit's Avatar
Finally used my saw. One warning that I didn't see with the gas model is not to force the cut - the motor may keep up speed but it will die soon.
You also need a 100' cord.
Old 07-21-2010, 10:07 PM   #18
As long as you are only cutting small stuff. The only problem is most people get tempted to do a job too big for the saw or get tired of waiting for the was to make the cut and push it too hard thats when accidents happend. I would not skimp on a chainsaw buy a good one.
If it is jsut small stuff sawzall works great. In fact I have a gas powered recipricating saw I got at a yard sale.
DIY1963 is offline   Reply With Quote
Old 07-21-2010, 11:04 PM   #19
" Euro " electrician
frenchelectrican's Avatar
For the little branches I just used the receptaing saw or hevey duty skillsaw one of the two { use the skill saw on buck only please } but for larger branch I use the gaz unit they will cut much faster.
There a nice tips from the pros whom cut wood all the time they told me that they keep two diffrent set of chains one set for soft wood and other set for hard woods { they run it everyday but pas moi.}
The other thing is do not put any pressure on the cutting bar or the blades let it work byself it will cut pretty good espcally true with chain saw let the weight take care of it byself.
Merci.
Marc
Old 07-23-2010, 11:40 PM   #20
http://www.arboristsite.com/ check out this website for serious chainsaw information.Pro loggers,Arborist's,Serious firewood cutters.I'm a member on there.Be Safe!
scarrylarry
scarrylarry is offline   Reply With Quote
Old 07-24-2010, 03:07 PM   #21
Moderator
Be sure to use the proper blade with the reciprocating saw, as the others bog down from the sap: http://www.skiltools.com/en/General/ImagePopup.html?img=http:______mdm.boschwebservice s.com___MDMCache___English%20[US]___t06___0000002___r02123v15.jpg&header=&thumbnail s=0
I used an older 16” Sears electric chainsaw for 25 years of framing, cutting 4x10 fir headers, 6x12, 7x21 glue-lams, para-lams (a lot denser), multiple TJI joists while bundled together upon delivery and 2x4 door plates without a break-down. Keep the blade sharp and oiled with WD40 works best for me.
Be safe, Gary
Clothes taking longer to dry?
Old 07-24-2010, 07:58 PM   #22
Yoyizit's Avatar
scarrylarry
Every book and video I got on cutting began with "In memory of. . ."
Raising overhead joists in my garage. Is this a good idea? jpearson311 Building & Construction 60 06-06-2012 09:25 AM
Laminate+stick on tiles+linoleum Good Idea?? K.M.G Flooring 5 02-21-2010 12:27 PM
When was this possibly a good idea? StevePax Remodeling 5 12-20-2009 06:56 PM
DH wants to buy me a Drill Doctor. Good idea/Bad idea? Leah Frances Tools 4 02-28-2009 01:46 PM
Refurbishing a water softener? Good idea? bugmenot Plumbing 4 02-07-2009 07:26 AM
