Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-17-2010, 12:39 PM   #1
Edge trimmer/fence posts
My landscapers when they trim around my fence are hacking the hell out of my cedar fence posts, I know more care should be taken, but most lawn people get in and get out, is their anything I can put around the bottom of the posts to protect them from the weed wacker?
turbomangt is offline   Reply With Quote
Old 10-17-2010, 01:13 PM   #2
jlhaslip's Avatar
I have seen people use pieces of the light weight metal lawn edging around fence posts for that exact purpose.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-17-2010, 07:20 PM   #3
Don't know it all, yet!
When I install fence posts I keep this in mind and put a border of concrete or even tamped down gravel one or two inches around. In other words, if you set posts in concrete, pour it all the way to the top. I usually pour it just a little above grade and smooth it to grade away from the posts. If you look closely, you can see the concrete or if you prefer, pour it at grade. Better than having to gouge the posts, etc. As far as the gravel, I don't mean leave it so high that it will pick up with weedeaters. Tamping it down good will discourage most growth and trimming will be minimal.
In your case, you could just dig out a collar and fill with concrete or gravel.
That's just how I do it.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
help settling porch posts - a dilemma. wombosi Carpentry 9 10-10-2008 01:01 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
