Easiest Way To Check If Sprinkler Has Leaks - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 12:53 PM   #1
Rewards Points: 93
easiest way to check if sprinkler has leaks
will water meter clock move if i have a tiny sprinkler pipe leaks?
dumbengineer is offline   Reply With Quote
Old 04-25-2013, 03:03 PM   #2
Rewards Points: 6
If there is a leak before the zone valves, then your meter will spin. That's how I check my system if it's leaking. If the leak is after the valve, the meter will not detect it.
Dan
djlandkpl is offline   Reply With Quote
Old 04-26-2013, 09:54 AM   #3
Too Short? Cut it Again!
Do you hear a slight hissing sound near the valves? Even if not, if you suspect a leak, have you checked to make sure the manual override screws on top of the valves have not worked loose? They may need new o-rings too.
Leaks on porch roof Pau-Latina Roofing/Siding 23 09-27-2012 03:36 PM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 06:36 PM
How can I stop leaks on porch Pau-Latina Roofing/Siding 6 06-12-2012 08:25 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 07:39 PM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 11:33 AM
