-   -   easiest way to check if sprinkler has leaks (http://www.diychatroom.com/f16/easiest-way-check-if-sprinkler-has-leaks-178074/)
dumbengineer 04-25-2013 12:53 PM
will water meter clock move if i have a tiny sprinkler pipe leaks?
djlandkpl 04-25-2013 03:03 PM
If there is a leak before the zone valves, then your meter will spin. That's how I check my system if it's leaking. If the leak is after the valve, the meter will not detect it.
user1007 04-26-2013 09:54 AM
Do you hear a slight hissing sound near the valves? Even if not, if you suspect a leak, have you checked to make sure the manual override screws on top of the valves have not worked loose? They may need new o-rings too.
