Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-19-2011, 11:09 PM   #16
Stay-at-home GC
dry stack natural stone retaining wall
So. this might be a nice compromise.
I beefed up your footer for the wall and moved the drain to the bottom back. This will let it drain both the wall and the patio.
I think the perf pipe has a place in the drystack walls as long as you keep it low. Raise it high and water will just shoot by.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
diy001 (06-20-2011)
Old 06-20-2011, 07:34 AM   #17
Originally Posted by CplDevilDog View Post
Depending on how far north you are, your gravel base may be a little light. 6" is recommended here in PA.
I am in MA. So I should be the same as PA. But some places say there is no requirment on base of drystack retaining wall because the wall can up and down due to they are loosely coupled.
diy001 is offline   Reply With Quote
Old 06-20-2011, 12:57 PM   #18
I have pipe for patio by design. The patio will be surrounded by a french drainage system for sureface water to keep them out from my house.
You can see a black pipe there from my first and third photo. That french drain system has been done last summer but the portion close to the retaining wall will be done after the wall.
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Retaining wall height cumak Landscaping & Lawn Care 2 05-10-2011 10:46 PM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 12:19 PM
Do I need drainage behind my retaining wall rakaschm Landscaping & Lawn Care 3 08-20-2009 07:45 PM
about to do my first retaining wall wombosi Landscaping & Lawn Care 2 06-08-2009 02:39 PM
