Dry Fit French Drain Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 12:37 PM   #1
dry fit french drain help
hello folks, long story short, replaced 87' of french drain. i am finally to the last section and it is a tricky fitting of one 4" pvc connector, one 45 and one T. i dry fitted it but i am hesitant to take it apart and cement it. extremely difficult place to access. can i find a product that i can use around the outside where the fittings come together to make sure i have a good waterproof seal ? i am confident that the fittings are tight, just want to make double sure. i hope to get it done before the rain returns on tuesday plus i have to pause and host a dinnner party this evening. thanks, madeleine
flyinferg is offline   Reply With Quote
Old 03-25-2012, 03:06 PM   #2
MarginallyQualified
Rewards Points: 2,464
Sure... it's called a "Sharpie" marking pen.
Measure the depth of your hub and mark the pipe for that "throat".
Dry fit... then glue it up and compress until the sharpie line meets the hub.
Old 03-26-2012, 11:23 AM   #3
Rewards Points: 1,548
Psst! French drain piping does not need perfectly watertight joints.
Cement just comes in handy so the pipes don't come apart as the gravel around them might shift in a near-surface installation.
Old 03-26-2012, 12:49 PM   #4
Work Hard, Play Harder
Rewards Points: 212
I'm not sure I would cement them. There is a tape they sell specifically for these pipes. As allanj mentioned; they don't have to be water tight joints anyways. I'd want to be able to take them apart at a later date.
The conditions of the property may change; hence changing the demands of the french drain system (eliminating it, or requiring a larger area).
coderguy is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
french drain interior location shadowbuilder Building & Construction 11 01-17-2012 10:10 PM
what to do with the french drain behind a retaining wall MLMIB Building & Construction 4 04-08-2011 07:52 AM
Determining existance of French Drain cmarti02 Plumbing 2 11-07-2007 06:51 PM
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 06:16 PM
