Driving Pickup Over Sprinkler Lines? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 08:49 PM   #1
Rewards Points: 310
driving pickup over sprinkler lines?
I have an in-ground sprinkler system. I know where all my heads are. We have a huge landscape feature in my front yard, and another in my backyard. Each will take a pickup full of mulch. I want to just back up to either vs. making 55 trips with the wheelbarrow.
Can I drive over the buried sprinkler water lines?
denemante is offline   Reply With Quote
Old 09-11-2011, 08:52 PM   #2
Rewards Points: 370
how deep are they buried? I would think that it shouldn't be a problem if they're more then 6 inches down but I think the big question is how deep are they.
MLMIB is offline   Reply With Quote
Old 09-11-2011, 09:02 PM   #3
Rewards Points: 310
Sadly, I have no idea how deep they are. It was installed by the previous owner. Didn't come with the house - they hired someone.
Old 09-11-2011, 09:19 PM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
Yes, you can drive over them, I have. However, don't park over them.
picflight is offline   Reply With Quote
Old 09-11-2011, 10:50 PM   #5
Registered User
Rewards Points: 526
If worried, find the lines location by "witching" with a 2' length of 12 gauge romex- minus the sheathing, twist them and bend a 6" L-shaped handle. Let the long side hang toward the ground, about 6" up, other short end balanced over two fingers, acts like a magnet, draws toward the line (poly, metal, clay tile, concrete, etc.)up to 10' deep. Finds re-bar in slabs, water lines, electrical wires, conduit, etc. Mark location/direction, cover with a 1/4 sheet of plywood, boards, etc. under tire path. Ground rod wire works even better.
Gary
Old 09-13-2011, 12:17 PM   #6
kmc
Make sure the soil is dry and you are fine.
kmc is offline   Reply With Quote
Old 09-13-2011, 12:55 PM   #7
A Little Of Everything
Rewards Points: 1,364
That'd make me very nervous, especially considering you don't know how deep they're buried.
The fact that you're doing this in the fall helps. The ground is drier and firmer.
I also like the idea of locating the lines, then putting a piece of plywood over where they are buried.
Good luck!
DrHicks is offline   Reply With Quote
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 10:44 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Sprinkler timer driving me nuts droopdog7 Landscaping & Lawn Care 2 09-28-2010 07:11 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 05:02 AM
