Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-31-2011, 07:08 PM   #1
Driving over buried pipe
Hi Everyone,
I'm constructing a garden themed park in my backyard which is roughly 2 acres. It will have two points of access from the front yard to the backyard. 1 through a flagstone walkway the other a vehicle path.
After entering the vehicle path you will soon need to drive over white piping that runs from my house, to my septic tank, then to my leach field. I won't need to drive across this often at all, maybe once or twice a year. My main concern is driving over it with a dump truck that has a load of mulch/dirt. Also, Later I plan to have a small lake added to the backyard which I will need to haul material away from and possibly have other large equipment back there...
-Will it hurt if a dump truck with dirt or mulch drives across this pipe a couple times a year?
-Will it hurt if I have other equipment drive across this repeatedly to construct a lake? I suppose if I decided to build a lake, I could have them lay some heavy steel plates on the ground to spread the weight?
ricksample is offline   Reply With Quote
Old 10-31-2011, 08:39 PM   #2
Super Moderator
Are they close to the surface? I think you need to add a plank road section over that area to distribute the weight---I did that for a landscape drain 20 years ago and I never had an issue.
Old 11-13-2011, 09:27 PM   #3
sdsester's Avatar
What schedule pipe is it?
sdsester is online now   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
