Driveway Gravel Base Is Too Wide. Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-05-2008, 06:58 PM   #1
Driveway gravel base is too wide. Help
The gravel base for my soon to be poured asphalt driveway is 2 feet too wide accordinf to my town. How can the asphalt be poured without somehow creating 2 feet of walled earth?
thanks
picsaro is offline   Reply With Quote
Old 09-06-2008, 03:46 PM   #2
Don't know it all, yet!
Too wide?
That's a new one on me. Maybe it's too close to the right of way or property line? Heard of a lot of problems with a base that is too thin, not packed, etc. but never too wide. Have you discussed this with a paving contractor? Does your town codes tell you it has to be removed? Do you know for sure that it's going to be a problem?
I suppose that this could come under hardscape, but just wondering if Construction wouldn't be more appropriate for this?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-06-2008, 10:11 PM   #3
I dont mean the gravel itself used is too wide. I mean the driveway basically needs to be moved 2 feet to the left to be in code, making the gravel base that was created 2 feet too wide on one side. I need to know if something could be place on the base to stop the asphalt from filling in that two feet in question.
thanks
Old 09-07-2008, 07:44 AM   #4
take up the base & move it to the other side,,, the paver screed determines where the blacktop mat'll be placed,,, save yourself the addl work & just move the base,,, OR leave it alone & add 2' on the other side.
blacktop is NOT liquid so it won't 'run' on you asphalt cement IS liquid til it cools but that's only an ingredient of blacktop (asphaltic cement concrete - stone - asphalt - sand - dirt )
yes.itsconcrete is offline   Reply With Quote
Old 09-07-2008, 10:11 AM   #5
thanks!
Just to make sure i understand you correctly, on the side that is too wide, i should be able to leave that as is (don't have to fill back in or place a border) and the asphalt can still be poured in a straight line 2 feet in from the edge?
Old 09-07-2008, 01:40 PM   #6
blacktop's not 'poured' - it is PAVED,,, blacktop's a mixture of heated rock, dirt, sand, which is sprayed w/hot liquid asphalt cement then trucked to jobsite,,, it is then dumped into a box & extruded from a paver under a heated screed & left as a soft mat,,, after its rolled, it further cools & becomes a flexible solid,,, short answer to your question's ' YES ! ! ! '
your paving guy already knows this - don't you trust HIM ? ? ? &, if not, why'd you hire him ? ? ?
Old 09-08-2008, 07:25 AM   #7
i trust my paving person. but when i called to tell them this needed to be done, the woman tyhere said she didnt know if it could be done and she'd get back to me. i guess she just didnt know the consistncy, like me.
thanks for the help.
Old 09-08-2008, 07:44 AM   #8
i'd bet you got a new voice at the answering svce,,, can't imagine any paving employee not knowing something this basic - good luck !
Old 09-08-2008, 02:56 PM   #9
this is an opportunity for you not to use asphalt at all...
and do interlocking to increase your porperty value.... consider when asphalt is applied, you need to spent thousands to remove it to do interlock... if you do interlock now... it is the best time and easiest way to do it... I wish I did that...
KUIPORNG is offline   Reply With Quote
Gravel Driveway covered in weeds cwest94 Landscaping & Lawn Care 8 11-16-2008 12:13 AM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 08:40 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
gravel driveway darren Landscaping & Lawn Care 4 05-15-2007 06:24 PM
Gravel Driveway WildCadillac Building & Construction 2 05-10-2007 12:53 PM
