Driveway Drain Grating - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 02:06 PM   #1
Driveway drain grating
I have a gravel driveway and at one point a heavy stream of water crosses it when it rains hard. I would like to put a steel or iron grating across the driveway at this spot. Traffic is typically cars and standard pickup trucks. Any suggestions on what I should use here?
moundtown is offline   Reply With Quote
Old 03-11-2013, 07:21 AM   #2
Rewards Points: 1,538
You should have a subsurface poured concrete channel on which the grate itself rests and which also serves as a collector for the water. There must be an outlet from one end of this channel to carry the water someplace else.
Old 03-11-2013, 11:41 AM   #3
Thanks for the reply. There is a semi-steep grade on one side of the driveway where the water drains naturally. Are there any prefabricated channels available?
Old 03-12-2013, 12:18 PM   #4
Rewards Points: 3,722
This is what you need.
http://www.shopping.com/Fernco-Fsd-C...-15938053/info
Canarywood1 is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
setting a shower drain Jackets Plumbing 16 05-10-2012 08:48 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
