Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-13-2011, 01:38 PM   #1
Drive belt problems
My drive belt keeps coming off when I turn my snowblower, any advise?
Larryjfr is offline   Reply With Quote
Old 01-13-2011, 05:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Drive belt problems
Ayuh,... It probably needs a new 1,....
Old 01-15-2011, 01:53 AM   #3
Drive belt problems
One problem may be that the guides that hold the belt tight, may be in the wrong position. The guides are thin metal bars that are held to the engine block with bolts. If they have shifted and are not holding the belt tight, when you engage the auger, the belt will come loose. Turn the blower off, replace the belt to the correct position and then position the guides so that they are making the belt tight, then tighten the guide bolts. This may not be your problem, but it's worth a shot.
joeg679 is offline   Reply With Quote
Old 01-16-2011, 02:33 PM   #4
Drive belt problems
Check to see that the belt is not skewed as it goes over the pulleys. If a pulley comes loose and slides up or down its shaft slightly, that causes such skewing.
Check to see that the belt is not too loose. On some models the idler pulley is controlled by the lever on the handlebars using a flexible cable. A turnbuckle like gizmo adjust the cable tension and also the amount of looseness the idler pulley can have.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-16-2011, 03:48 PM   #5
A Little Of Everything
Drive belt problems
Well, first of all, replace the belt. It will be no more than $25 and is something that eventually needs to be done anyway.
If it continues to slip off, the next step is to look closely at the idler pulleys and/or clutch mechanism. You could have a bent pulley, or bearing shot, or any other number of things.
Still, your first step is to replace your belt.
DrHicks is offline   Reply With Quote
Old 01-18-2011, 07:05 PM   #6
Drive belt problems
Thankuou for all your help, I will try rverything.
Satellite Rx external hard drive. Wildie PC Repairs & Upgrades 4 09-14-2009 12:06 AM
Moving C drive files Thurman PC Repairs & Upgrades 14 08-17-2009 04:13 PM
Belt care... RippySkippy Tools 3 12-25-2008 02:43 PM
Need held adjusting Craftsman Band Saw and Belt Sander tripower Tools 2 12-13-2008 09:23 AM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
