Drip Irrigation Vs Mister - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 05:06 PM   #1
Rewards Points: 12
drip irrigation vs mister
I am looking to correctly water a flower bed that contains trees, shrubs, and smaller plants. I know that it would be easier to install the pop-up heads that would spray a fine mist over the entire bed but is that the correct way to water the flower beds? I assume that drip irrigation ran to the base of each individual plant would be the preferred method. Less wasted water and also less chance of issues with leaf or stem issues like fungus and bugs since they are not going to be staying as wet. Any suggestions or opinions?
GLS0628 is offline   Reply With Quote
Old 06-25-2012, 08:30 PM   #2
I just installed a drip system and you can actually use both.
I used the Raindrip brand system and with their products you can hook up drips and what they call micro sprinklers (there is several other watering types they have) to the same line.
So you can design the system based on what the plants need, so for my trees, rose bushes, vines, for example, I ran drips right to the base while some of my ground cover just has a series of micro sprinklers on them.
It all depends on what would be best for the flowers you're going to be planting.
So check out Raindrip's website, also Rainbird makes some drip systems, and I'm sure there is other brands out there as well.
tjansen is offline   Reply With Quote
Subsurface Drip Irrigation a_lost_shadow Landscaping & Lawn Care 2 03-25-2012 06:32 PM
How do I properly set up a Drip Irrigation system? Telfair Gardening Forum 7 03-25-2012 08:35 AM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 11:40 PM
drip irrigation system Master Brian Landscaping & Lawn Care 1 03-31-2011 11:20 PM
landscape irrigation system drip tubing remodelingagain Landscaping & Lawn Care 26 08-19-2009 09:17 AM
