Drip Irrigation Help! - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 06:41 PM   #1
I put together a drip irrigation system that looks as follows.
1 - From a garden spigot => small lead hose => multi connector manifold => timer valve (attached to an orbit timer) => 20 psi pressure regulator => pvc adapter => hose connector => 1/2 inch drip irrigation hose => connector => 1/4 inch drip irrigation tubing => 1/2 gph red drip emitter.
2 - The half inch tube runs around the garden as follow
26 feet straight (part 1) => elbow connector => 5 feet (part 2) => 30 feet straight (part 3).
3 - I have for 1/2 gph emitters towards the end of part 1 and one sprinkler type emitter towards the end of part 3.
When I turn the system on (I have the spigot turned on only ust a little bit), either manually or automatically for 1 minute..the 4 1/2 gph emitters are spraying a stream of water instead of dripping.
What am I doing wrong?
Here is a picture of the system.
[IMG][/IMG]
tinsingh is offline   Reply With Quote
Old 03-30-2013, 07:04 PM   #2
Rewards Points: 34
Has the system ever worked correctly? If yes, I would say the pressure regulator has gone bad.
Dan
djlandkpl is offline   Reply With Quote
The Following 2 Users Say Thank You to djlandkpl For This Useful Post:
tinsingh (03-31-2013), user1007 (04-01-2013)
Old 03-31-2013, 01:10 AM   #3
No, this is the first time I am trying this one out.
Old 03-31-2013, 09:41 AM   #4
Rewards Points: 34
I would try swapping out the pressure regulator. It's one of 2 things, the pressure regulator or the emitters have dirt in them. I tend to doubt all of your emitters got clogged on a new system.
On a side note, 1 minute of watering isn't going to do anything. With drip, you should be running 45 to 60 minutes for deep penetrating watering.
Dan
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 03-31-2013, 10:03 AM   #5
funfool's Avatar
Rewards Points: 534
I would also suspect the pressure regulator.
I have setup 3 different drip systems for myself and for others. This means I know a little but not a lot
I usually start with a kit from home depot, is cheap and has everything you need to get started, and just add to it from there.
I have had defective pieces right out of the kit and had to return those pieces before.
On the other hand, my system is on its second year and never given any problem.
I kinda thought the emitters were colored coded, and the reds were the big 5 gph?
I suppose this could change from one brand to the next.
One thing I have found about sprayers, I would try to isolate them to run individually or at different times.
They use anywhere from 14 - 20+ gph and will rob the rest of the system of water.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
Old 03-31-2013, 10:18 AM   #6
Rewards Points: 34
I thought about this some more.
Connect the pressure regulator directly to the spigot and see if it fixes it. If it does, then all the stuff in between is bleeding off too much water pressure and the emitters think the system is off and they are bleeding off excess water. If it doesn't, then most likely it's the regulator.
+1 on funfools suggestion on sprayers being on separate zones.
Dan
Old 03-31-2013, 10:42 AM   #7
Rewards Points: 79
Maybe your 1/2gal emitters are plugged. I do not see the orbit timer in the pic. Does the sprayer valve work? I would think too much pressure would impact more than just the 1/2 gpm emitters.
Good luck
Gary
gobug is offline   Reply With Quote
The Following User Says Thank You to gobug For This Useful Post:
Old 04-01-2013, 03:05 PM   #8
Folks,
Thanks for your help.
It turns out I had using the inline emitters instead of end of line drippers.
Old 04-01-2013, 10:52 PM   #9
Too Short? Cut it Again!
You might try pressure compensating emmiters. But I must agree you have a pressure problem. You did buy drip and not misting emmitters right? I used to specifiy cuties that could be configured to either drip or mist.
What is the psi water pressure to everything in your house by the way. If it is too high you are potentially in for all kinds of plumbing problems. As typed, I think you have a bad pressure regulator. Some of the cheap ones can only handle so much coming at them though.
Ideas for drip irrigation? funfool Gardening Forum 3 03-31-2013 10:28 AM
Fertilize through drip irrigation? ldb Landscaping & Lawn Care 3 08-02-2012 06:39 AM
Subsurface Drip Irrigation a_lost_shadow Landscaping & Lawn Care 2 03-25-2012 05:32 PM
How do I properly set up a Drip Irrigation system? Telfair Gardening Forum 7 03-25-2012 07:35 AM
drip irrigation system Master Brian Landscaping & Lawn Care 1 03-31-2011 10:20 PM
