Draining A Wet Area In Backyard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 01:39 PM   #1
jbk
Rewards Points: 12
Question
Draining a Wet Area in Backyard
Hi,
Our house is on a 5000 sq ft lot, which generally slopes mildly from back to front. The soil is very clay soil, containing lots of small to big (up to egg-sized) rocks. Our back patio is a cement pad, and just next to it and alongside one side of the house, water tends to pond up when it rains. It doesn't drain for many days after the rain stops. I'm thinking about putting in a "French Drain" (a buried pipe) or "Trench Drain" (a trench w/ gravel) from next to the patio, along one side of the house and out the front to help drain the water. Is this a DIY project? Is this going to affect the foundation somehow if the trench is too close to the foundation? Our foundation is a slab, and the trench would be about 2 or 3 feet from the slab.
Thanks.
jbk is offline   Reply With Quote
Old 02-12-2009, 02:47 PM   #2
Remodeling Contractor
You can do it yourself. 2-3 is too close. I would stay 6-10 foot away You do not want to disturb the clay soil close to the foundation.
Old 02-13-2009, 07:54 AM   #3
47_47's Avatar
Rewards Points: 58
Bob's right about the 6-10'. Where do your downspouts drain? If they are draining into the side yard, consider putting in 2 pipes. One perforated for the ground water and another solid for your gutters in the same trench. You will either have to end your pipe(s) to daylight or a dry well.
47_47 is offline   Reply With Quote
Old 02-13-2009, 08:58 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,....
If your lot is sloped from back to front,+ it's ponding,...
That says the grade isn't continuous,...
The Simplest possible Fix is to bring the dirt that's causing the dam, up the slope in order to make the slope Continuous....
Bondo is online now   Reply With Quote
Old 02-13-2009, 11:46 AM   #5
47_47's Avatar
Rewards Points: 58
If you put dirt on top of clay to bring up the grade instead of a pond, you'll get a mud pit.
Old 02-13-2009, 12:41 PM   #6
jbk
Rewards Points: 12
Question
Yes, I don't think I'd do that. I'd prefer to put in some sort of a drain. I think it'd make more sense if I could show you all some pictures.
Anyhow, the part that concerns me if I were to put in a drain is that the trench would have to go alongside the house, and there just isn't that much room there -- our neighbor's property/fence is very close. I think I can put the trench about 4 feet away from the slab foundation, which makes me a little nervous.
And I'm not sure about 2 feet deep, which is what I see recommended. On that side of the house, towards the front where the trench would come out, there are utility pipes buried. I'll have to check w/ the Digg-Safe people.
-J
Old 02-13-2009, 02:25 PM   #7
Bondo's Avatar
Ayuh,... Which is Why regrading would be Better....
Regrading requires Nothing below the surface,...
Nothing to Freeze,...
Nothing to Plug,...
Nothing to Leak....
No investment for materials,... Use the clay you have,...
Then a couple inches of top dirt,+ you're reading for grass...
Btw,... A simple stringline will tell you where to cut,+ where to fill.....
Old 02-13-2009, 02:34 PM   #8
Rewards Points: 1,910
I'm in for regrading too.
Old 02-13-2009, 02:56 PM   #9
47_47's Avatar
Rewards Points: 58
You're comment about bringing the dirt was a little vague.... Agree with using the clay to fill the depression/set a proper grade, then top dress.
Old 02-13-2009, 03:38 PM   #10
Bondo's Avatar
Ayuh,.. Sorry about that,...
1 finger typing tends to keep my answers short,...
I should have mentioned using the native soils....
With the OP's other thread about Tilling,...
Regrading should be reasonably Easy, because of the busted up sod...And Dirt,....
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 10:33 PM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 09:19 PM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 01:56 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
