Drainage Through Concrete Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 06:04 AM   #1
Drainage through concrete driveway
I just added a stamped concrete driveway. Two issues, but related.
(1) I may have covered too many roots of a nearby tree. (I know, I should have thought of that sooner.) Is it possible to drill holes in the concrete to allow for some drainage? If so, are any special 'things' to know about? Are there any tubes that I can/should insert to maintain strength? Am I heading in the wrong direction?
(2) There are areas where the stamp is so (relatively) deep (but still only about 1/2 inch) that water pools. Even the hot sun doesn't evaporate the water, and if there is no sun, well it just sits to the next day. Same question, but this one aimed at providing an escape route for the pooling water. Can I drill into the concrete?
Roy
Roy1953 is offline   Reply With Quote
Old 08-30-2009, 09:48 PM   #2
Rewards Points: 1,088
Roy
Drill a hole?
If you live in an area that has a cold winter, that spot could be an issue b/c it will freeze.
handy man88 is offline   Reply With Quote
Old 09-02-2009, 08:07 AM   #3
Mabye you could cut in some extra relief lines with a concrete saw, going from shallow to deep?
Stillwerkin is offline   Reply With Quote
Tags
concrete , drainage , driveway , water
concrete driveway repair butlerx2 General DIY Discussions 1 04-20-2009 06:03 AM
concrete driveway sinking phospher Building & Construction 13 04-06-2009 07:27 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
